Need affordable PC case in India — front USB-C, no glass panel
Looking for a budget PC case in India with:
  • No tempered glass (solid/mesh side preferred)
  • Front USB-C port
  • Good airflow and sound-dampening
  • Budget 8000 INR
  • Having pre-installed fans is a bonus.
  • Need stealthy look. No fancy RGB lighting or designs.
Something like the Antec Performance 1 Silent (link) but more affordable. Any recommendations?
Check Antec P20CE.
@BIKeINSTEIN yes Antec P20CE is good option around 7k rupees.. i will wait for more suggestions Thank you
List out your specific wants and want nots. @subm16
I purchased the Lian Li Dan A3 mATX case and I absolutely love it. It’s got mesh side panels, support for long and heavy GPUs, room for a heck ton of system fans. I have built two systems in it so far and the process was a breeze with this case.
Mounting the PSU, hard-disk drives/SSDs are simple. Air flow is good if you have the correct fan configuration set up. I have two intakes at the bottom for the GPU and one exhaust at the back (maybe I’ll change the exhaust to top). The front panel connectors are stitched together and simple to connect. It’s got a front USB-C.
It being a mesh panel means air flow will be slightly better but the noise will leak out under heavy sustained loads. I purchased mine for INR 7,900/- from Computech but it was the wooden variant (for asthetics :sparkles:). If you’re looking for a stealthy look, you may go with the all black variant. You’ll save some money on it too.
Go with Antec P20CE (solid side variant) — it is the only case under ₹8K in current Indian online retail with a solid side panel and front USB-C.
If you’re okay with a tempered glass side panel, the best available options under ₹8K are:
CORSAIR Frame 4000D — front USB-C, excellent airflow (Best IMO)
DeepCool CK560 — front USB-C, good airflow, includes 4 fans
Thermaltake View 270 TG — front USB-C but tempered glass front and side, less airflow than above
@cattynip Nice suggestion, looks good! But I’m not sure if a mesh panel is ideal for a dusty environment. Do you notice dust building up inside over time?
Yeah, I don’t want a glass panel, I want to hide my PC internals and bad wire management :joy:
P20CE looks like the perfect option then if there’s nothing else in that range. Thank You @TADPOOL
Yes, dust will build up over time more-so as it has mesh side panels. Mine comes with two dust filters, one for the bottom intake fans and the other one at the front of the case for PSU air flow. I have the PSU oriented towards the front for the same reason. I clean the filters every two weeks and a deep clean once in 6 months.
