What is your budget?
- 150k - 175k
[*]What is your existing hardware configuration (component name - component brand and model)
- Fresh Build (Apart from peripherals - Mouse and Keyboard combo Logitech K-260)
[*]Which hardware will you be keeping (component name - component brand and model)
- Mouse and Keyboard - Logitech K-260
[*]Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.**
CPU - Intel Core i5-8600k
Motherboard - ASRock Z370 Killer SLI/ac LGA 1151 (Any other compatible motherboard suggestions?)
GPU - GTX 1080ti
RAM - 16 GB (2x8 or 1x16 whichever’s more convenient) (Found Crucial and Corsair at the top in Amazon’s popular products)
SSD - Samsung 960 EVO 250GB NVME M.2 SSD V-NAND MZ-V6E250BW
HDD - Seagate Barracuda ST2000DM006 2TB HDD
PSU - Corsair CS-M Series CS750M (Newegg Link for ref)
(The following cooler and case were chosen by just searching on Amazon and selecting the popular products. Didn’t know what to base the search on so have no idea about its compatibility with the other parts.)
Cooler - COOLER MASTER LIQUID COOLER - MASTERLIQUID LITE 120
Case - Corsair Carbide Series CC-9011050-WW Mid-Tower Steel Gaming Case with Red LED (Black)
[*]Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
Yes, will upgrade the following (as per required in the future)
RAM - Extend from 16 to 32
[*]Where will you buy this hardware? (Online/City/TE Dealer)
Pune (Thinking of getting all the parts from one store if possible, so that return policies and warranties can be handled appropriately)
Open to online purchase
[*]Would you consider buying a second hand hardware from the TE market
- No
[*]What is your intended use for this PC/hardware
Deep Learning
Will be used to train models, which could go on for multiple hours, days even)
Heavy computations on GPU
[*]Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
- No. But would appreciate a reliable manufacturer with good post sales service
[*]If you will be playing games then which type of games will you be playing?
- No
[*]What is your preferred monitor resolution for gaming and normal usage
- No preference. Would love some suggestions.
[*]Are you looking to overclock?
- No. ( Have never overclocked a CPU ever. So don’t know if I would require to, in the future)
[*]Which operating system do you intend to use with this configuration?
Windows 10
Linux - Ubuntu (and any other distro)
Notes:
1. I have checked basic compatibilities like CPU-Motherboard chipset compatibility and multi-GPU SLI support if required.
I need help checking for overall compatibility of the build. Open to suggestions.
**2.** I haven’t built a PC in my life (I have owned one without any knowledge of it’s parts and now its scrap).
**3.** Any compromises if at all visible in some components might be due to the priority given to 1080ti. (Like CPU)
**4.** Any misfit items chosen might be due to my inability to understand 😛
