As the thread title says, need help choosing between the B850 and X870/E motherboards.
For example many motherboards with these chipsets are around similar price point like:
Asus ROG Strix B850-F - 34k
Asus Prime X870-P - 35k
ASRock X870E Nova - 37k
I have no use for the USB 4. Not even in the near future. I’m good with the USB 20gbps for a long time.
I also prefer the Intel 2.5g LAN in the B850-F. No need overclocking except for RAM XMP/EXPO.
Most probably will be pairing with a Ryzen 9900X CPU and 6400/7200Mhz 2x24GB RAM.
So I’m planning to get the B850-F. Please tell me what am I missing?
Isn’t the Asrock X870 pro rs much better, it has all the features + usb4 and is available for 22k?
The B850 boards have just recently launched and not many options are available and the price are also quite high so of you want a cheaper board B650 is a no brainer. But if you want to spend over 20k then go for the X870 boards as they have all the features of the x670 boards + some extra features at the same prices.
Not preferring the B650/X670/E because I want the latest model number, they also have better resale value and better traces esp. for DDR5 higher speeds and stability.
Then, I want an Intel NIC as it has the least amount of issues with drivers esp. with Linux. Sadly, I’m yet to find an Asrock board with an Intel NIC. Most Asus boards have Intel NIC. Asus also has better BIOS UI. Other than that Asrock are good
Also the problem with the X870 is that it wastes precious PCIE lanes on useless (for me) USB4. So have to go for the X870E.
Asus B650E-F has Intel NIC but it is the older one. also 12+2 power stages.
Will do more researching and thinking for atleast a month till I say fk it and buy something
The pro rs actually has an accessible m.2 wifi card which you can replace for an intel one and for the ethernet you could add a separate card. Can’t do much about the wasted lanes on usb4 though as I suspect that most Asus x870 boards are going to have that by default.
IMO B850 is worthless. Either go with B650 budget models as many suggested OR get the latest X870E. Gigabyte Aorus elite is decent/Asrock taichi is the best.
OP also mentioned he wants the latest chipset so suggested the X870E model. B850 Mobo for 34K is utter garbage, dont want anyone go near that.
You never know, one day you might want USB 4.0 OR AMD launch new CPU that gets faster support for X870E over the X670 like they did with AM4 5000 series/B350 chipset
OR you have bad OCD problem that cant accept X670 for 9000 series CPU.
yes I do have the bad OCD problem :arghh: also the only thing stopping me from getting the X870E Nova are the issues with the Realtek 5G Ethernet NIC esp with Linux.
guess I have to brute force my OCD and settle with a B650/E Mobo.
I bought asrock x870 pro rs wifi cost about 23k-24k should be able to run 9900x I got the 9700x, Look and compare the features and if you don’t need so many bells and whistles get something lower.
