Need help - error - Chassis Intruded
Hey guys,
This something new to me & I am not able to enter bios. I had dismantled my PC for cleaning + upgrades & now I am getting this error.
New CPU Installed! Please enter setup to configure your system.
Chassis Intruded!
Fatal Error…System Halted.
Am using Asus P5Q E mobo with Q9550, if anybody has a clue pls help me out. It is very annoying.
Thanks
Reset/Clear BIOS using the Jumper on the Mobo, or remove the Button cell on the mobo and power on the machine after a min or so shutdown the machine put in the battery again…
No need of all that ^^
There is an option in the BIOS
  • Chassis Intrusion Check -
And a connector on the Mobo for the same.
Disable the option, as anyway 99% cabinets do not have the connector for this feature.
For New CPU, just enter the BIOS, do a save settings, and exit.
He has already mentioned that he is not able to access BIOS,
And the Chassis Intrusion Check is disabled in BIOS as Default settings…
And thats why i have mentioned resetting the BIOS will disable the Chassis intrusion
and he will be able to Access BIOS too…
Thanks mate, this fixed it. :slight_smile:
