Hi folks,
I am planning to buy a servo stabilizer for my home. Rating requirement is around 2 kVA.
I am looking for trusted brands which have good presence in Pune.
Thanks!
Hi folks,
Thanks!
no recommendations as such, but 2kva seems very low? are you sure you have measured it correctly? for context, we currently have a 15 kva servo which supports upto 5 ACs (mostly 3 ACs running in parallel), and assorted lights/kitchen equipment etc.
One more thing, if your requirement is x, and if you are fine with a little wastage, get x+5 kva at a minimum, your future self would thank you, we personally are considering upgrading to 20kva
Which one do you have? I am also looking for 15-20kva for home since voltage here fluctuates quite a lot.
I will not be putting the ‘power’ phase on the servo stabilizer.
Currently, I am running
in another home just fine but it is a ‘cutoff’ type of stabilizer and not a servo one.
I think 3 to 5 kVA rating for the non-power phase should be more future-proof for me - thanks!
I use 10KVA 90-270V stabilizer from Golden Servo. Pretty happy with it, using it for over 1 year and no complaints at all
Thanks!
I will measure the amount of space I have and get the highest capacity single-phase servo stabilizer that fits in there.
