Need suggestion for a cordless and a landline phone
In urgent need of a cordless phone, as well as a good landline phone
Caller id is a must in either case. Prefer a backlt one.
  1. Brand: Any good brand like Panasonic/Beetel etc. Beetel preferred.
  2. Would prefer that it should have base set dialing option
  3. Would prefer a non glossy set
  4. Power cut proof preferred
  5. 5.4Ghz preferred
  6. Budget: 5500/-
For Landline:
  2. Would prefer a non glossy set
  3. Budget: 5500/-
This ll be a retail shop purchase. You can def suggest via website/shopping portal’s links for reference :slight_smile:
Pls do post your suggestions guys
Hello
you can buy Panasonic Cordless KX TG-3615BXS Landline Phone
I share its features with you
Digital speaker phone
Customize your phonebook with a choice of preset ring tones
Night Mode : Disable rigtone during selected hours
Ringer ID*1,*2
2.4 Ghz frequencynhopping spread spectrum (FHSS) digital technology
50-Station phonebook & dialer
Caller ID with 50-station cll log*1
IIIuminated display on handset.
Light-Up indicator with ringer alert
you can buy this in just Rs 2049 on snapdeal
Another phone according to your choice
Panasonic Cordless KX-TG3651
Hand-free speakerphone on handset and base unit.
100-Name & number phonebook on handset.
IIIuminated Display & keypad on handset
Large, Easy -to-read display & simple menu operation
Power cut proof (corded handset will work if there is a power cut)*1
2 Phones in 1(corded plus cordless handset)
30-Station caller ID memory & dialer*2
Up to 3-way conference capability
Caller Rejection*2
One touch dial
Rechargeable batteries (AAA(R03) Ni-MH).
You can buy this in just Rs 4699 on snapdeal
I also need a good normal caller id phone for my home cordless one but not so costly. It should be good and last for a long term. Can anyone suggest here some good ones.
Hi John4321
you can buy Panasonic Corded Phone KX-TSC60SXW with 12 months warranty online.
Basic phone
Caller ID memory corded base and corded handset
30 call log
Ring tones
Are you satisfied with these features
