I already have the Benq EW2480 Full HD monitor for both work and gaming(Xbox Series S).
I feel that for the size of 24 inch FHD is kind of zoomed in. I thought of buying a 24" inch 2K monitor under ₹22-24k.
Additional requirements:
Minimum 3 inputs, HDMI, DP or USB C are fine
No need for VGA
No mandatory need for the in built height adjustment as I have the Monitor Arm already.
Occasional gaming with a mediocre desktop with RTX 2060 so refresh rate >=75Hz is good
In built speakers is good to have
Preferably from the sellers who offer EMI, special requirement
Shortlisted Ones
Viewsonic Vx2480-2K-Shd, 24 Inch (60.96 cm), 2560 X 1440 Pixels, LCD, Qhd Resolution Superclear IPS Entertainment Monitor (75 Hz Refresh Rate, Hdmi, Dp Port, in-Built Cable Management), Black Amazon.in
Samsung 60 Series - Ls24A600Nwwxxl, 24 Inch (60.4 cm), 2K Wqhd Flat Computer Monitor 2560 x 1440 Pixels, IPS, Hdr10 (1 Billion Colors), Height Adjustable Stand, Eye Care, 75Hz (Black) Amazon.in
Lenovo Q-Series Q24H-10 24 Inch(60.45Cm) LED 2560 X 1440 Pixels 2K QHD Ips Ultraslim Monitor, All-In-One Usb-C Port For Power & Data Transfer, 2 X 3W Speakers, 99% Srgb, 75Hz, Amd Freesync (Warm Grey) Amazon.in
I am aware that Series S is FHD only and sucks at 2K rendering
This is my first post after some simple WTB threads, so please correct me if I am missing any rules here.
Now I made up my mind to upgrade to 27 inch. I could see that there are a plenty available. I am looking into the following list to get reduced.
Acer Nitro XV272U KV 27 Inch WQHD IPS Agile Splendor Gaming LCD Monitor with LED Back Light Technology I 1 MS 170 Hz I 400 Nits I AMD Free Sync I TUV/Eyesafe I 2 X HDMI Display Port with Cables
My budget is max 25-28K and as I already mentioned, I already own a FHD, which I cannot replace. Please suggest me one either from above list or any new entries is also welcomed! TIA
