My 22" viewsonic went kaput sometime back, I think the back light went kaput. Have been using my 17" compaq crt since then, but I think its time for an upgrade.
I checked out 24" led’s but they didn’t seem that much bigger than my 22" 16:10 viewsonic, they only seemed to be a bit wider.
So have decided to go in for a 27 incher, but cannot decide between the following.
Acer S273HL - Its a TN panel with LED back lighting, I liked it. but this review discourages anyone from buying it :huh: Got a quote of 19k for this from prime.
Benq M2700HD Again a TN panel, has ccfl back lighting, so is thicker. Has speakers and lots of connectors which i do not need. Got a quote of 23k for this. I dont know if I should trust ccfl backlit lcd’s since my viewsonic went kaput 1 day after the 3 year warranty got over.
BenQ EW2730V Its has a VA panel with LED back lighting, I liked this too, but it is no where to be seen :huh:
My primarily use will be for watching movies and browsing the internet, I feel 1920x1080 should be adequate for that. I can spend upto 25k. Which one should I go for?
I feel 24 will be too small, I didnt see much of a size difference between my 22" and a 24". My room is 14x11x10, i’ll be sitting arnd 7-9ft away from the monitor, only while watching movies. While surfing/working I intend to sit in front of the monitor.
I want this to be a one time investment for at least the next 3-4 years, that’s another reason I dont want a 24". Are 32" hdtv’s any good for surfing/normal pc work?
Yes although they may not be a match to a 24 incher/27 incher LCD monitor. If games and HD movies are the priority, get a full-HD HDTV. Will set you back by 28~32k.
I connected my laptop to a friends sony 32" full hd 3d led today, movies and games were amazing. But surfing the internet/chatting/browsing through folders and stuff seemed weird. Since the acer has reverse ghosting issues, I think I’ll wait for the Benq EW2730V to hit the market and get that.
Some of the forum members use a 32inch LCD as the primary display. Udit, Shripad, thexfactor, Sharekhan are some of them I know of - maybe you can ask them how worse does the display fare when it comes to internet browsing, document editing and so forth.
I’ve decided to save up for a 32" samsung series 5/6 led tv but if the benq gets released before I am able to save up for the tv, then will get the benq itself.
I thought of the dell 27" too, but since its said to have ghosting issues while gaming I’ve opted it out(my bro will be playing games, forgot to mention that).
u will be wasting ur moolah if u buy any of those monitors…heck u wud be better off buying a cheapo 26" LCT TV…if u want quality for watching movies & games go for either a Dell ultrasharp 27’ or a apple 27" cinema display… the ultrasharp will cost a bit less than the apple & at the same time offer u a more wider range of connectivity
