Hello Folks,
I need to buy a router for my house so kindly suggest me one. The router should offer wireless connectivity from my PC room to my master bedroom which is about 60 feet away. There are 2-3 walls (normal 6" walls) in-between my PC room leading to the bedroom but each of them has doors which remain open most of the day. Connected devices will be as follows:
LAN: Main PC, Secondary PC, Netbook.
Wi-Fi: Phone and Tab.
I will be not be connecting any HDD’s to the router as my main PC is ON 24/7 and does all the needed downloading. Essential data backup’s are taken by me on Sunday’s as a ritual on my secondary PC (mainly used as a data dump PC) over LAN.
I prefer to get one from Asus (they are easy to setup and their CC helpline regarding routers is great from my past experience with them) so kindly suggest accordingly. I was thinking about the Asus RT-N14U but if there are cheaper options available, then I’ll gladly go for them.
Regards,
Black_Hawk
