Need urgent help for a ADSL2+ Modem Router
Hi i m looking to buy a ADSL2+modem wireless router and my budget is 4-5k so pls refer me a good modem router :slight_smile: thx
I have picked up a few ones tell me which will be a best buy between them
1.) Belkin N+ modem router (F5D8635sa4A)
2.) Netgear N300 - DGN2200
3.) Netgear N300 - WNDR3300
4.) Linksys WAG120N
5.) Asus DSL-N13
pls tell me today only as i have to buy it tomorrow so pls help
Are you looking for normal usage or DD-WRT ?
Linksys WAG120N will do the job
Avoid belkin, it has some connection drop issues.
mainly i m looking for gaming purpose so that i get good ping and no lag issues
— Updated Post - Automerged —
ok thx for pointing the cons of belkin. Howz Netgear ?
