Nvidia G70 is a single slot cooling design
Some information on G70
Source
2 words, its INQUIRER. How can we trust em :wink:
They like to post all masala stories.
Anyway it dosent matter that much to the high end user if its single slot or dual slot design. The value/mainstream products should be single slot.
I think its fairly well known that the G70 will be a very powerful chip and the performance difference between it and the 6800U will be 2-3x at the very least.
So even the 6600 may not be a good future-proof choice 2day coz a G70 based mainstream part may outpace it by several times.
^^ You yet never know, let them come out, it will take atleast a year before the next generation mid range chips roll out. And yes 6600 GT will get cloberred if not by the next generation chips then atleast by X800 or even X800XL which price is decreasing big time.
dude what is the cost of x800 in india?
also,mid range cards should be out by late this year max , shouldn’t they,though that time they may cost higher
should i go for geofrce 6600gt then,i won’t be able to upgrade for 2 yrs
Yup…never know until the cards come out…
Also not sure about how many pipes thr gonna carry nd real specs??
so its really too early to make out nythng
only a head to head comparison will show :wink:
