NZXT Source 210 Elite Mid Tower Cabinet
Features
•5.25” and 3.5” Screwless Design – Allows easy setup or removal of optical and hard drives.
•USB 3.0 – Provides the most up to date high speed data transfer.
•140mm top fan included – Maximizes cooling potential.
•Bottom Mounted PSU – Positioned for the most effective PSU ventilation
•Wire Management Support – 20mm space for a neat and easy build
•Aluminum Textured Panel – Accents the chassis for a clean, modern look and feel
•Dual 120mm Front Intake – Takes advantage of front facing HDD bays for excellent airflow
•Maximum Cooling Potential – Eliminate heat by installing up to seven 120mm fans
Midtower
NZXT’s Source 210 Elite is here to provide the basic chassis to house your rig and a just a little more to meet your needs. Now with USB 3.0, tool-less features, and an additional 140mm top fan for cooling, it’s modest and contains the essentials for performance. It’s the chassis you can afford, and more.
The Source Series is NZXT’s chassis line designed to be a starting block for first time builders or a stepping stone for those who want to upgrade their rig later on. Each chassis faithfully serves their purpose as an affordable, memorable part of your system building experience; it may just be a keeper.
**MODEL : Source 210 Elite
CASE TYPE : Mid Tower
FRONT PANEL MATERIAL : Plastic / Aluminum-like finish
DIMENSIONS (W x H x D) : 195mm x 440mm x 495.5mm
VGA Clearance Maximum : 230mm w/ hard drive, 330mm w/o hard drive
CPU Heatsink Support : 160mm
Wiring Space : 20mm
COOLING SYSTEM : FRONT, 2 X 120mm
REAR, 1 X 120mm @ 1200rpm (included)
TOP, 1 X 140mm (included)
BOTTOM, 1 x 120mm
DRIVE BAYS : 3 Tool-less EXTERNAL 5.25" DRIVE BAYS
8 Tool-less INTERNAL 3.5" HDD Drives
MATERIAL(S) : Steel with painted interior
EXPANSION SLOTS : 7
WEIGHT : 6.5kg
MOTHERBOARD SUPPORT : ATX, MICRO-ATX
External Connections : 1 x Standard Audio/Mic, 1 x USB 3.0,1 x USB 2.0**
Payment Options - Online Transfer, Cash Deposit, DD to HDFC / ICICI Bank A/c
Rate : Rs.2300/-
Shipping : Depend on Location
Deal : Valid till stock last
Email me (Support@PrimeABGB.com) to Confirm your Orders with your details like.
Full Name
Shipping Address with Landmark
Contact No. (Mobile No. preferred)
[Read Policy](http://www.primeabgb.com/index.php?option=com_content&view=article&id=1574 :open_mouth: ur-policy-for-techenclavecom&catid=37:news-views&Itemid=63)
Price : Valid only for Techenclave customer, not valid in PrimeABGB store and PrimeABGB.com
Currently NZXT Source 210 Elite Mid Tower Cabinet is not in stock, shall update you with the availability ASAP.
