OCZ Technology Group, a worldwide leader in innovative, ultra-high performance and high reliability memory, today announced the release of the exclusive PC-5000 EL Platinum series, a line of memory specially designed for use with DFI nF4 motherboards.
As a recognized pioneer in offering the highest possible memory frequencies, OCZ developed the PC-5000 Platinum DFI nF4 Special series with performance enthusiasts in mind. This ground-breaking member of the proprietary OCZ Platinum series is custom-built for premium operation on the highly-popular DFI nF4 motherboard series. At the extreme speed of 625MHz, the OCZ PC-5000 Platinum is still capable of achieving blistering timings of 3-4-4-10!
“The OCZ PC-5000 EL DDR Platinum DFI nF4 Special underscores the commitment of OCZ to work as closely as possible with the motherboard manufacturers to achieve the highest possible performance,†said Dr. Michael Schuette, Director of Technology Development at OCZ Technology. “Whoever provides the infrastructure to enable high memory speed will receive full support by OCZ Technology. In other words, you ask for the seemingly impossible and we will work with you to make it happen.â€
“Motherboards and memory modules are always considered the two most critical factors for achieving excellent performance, but truly perfect matches can be challenging to find, and a tailor-made memory module for a specific motherboard catering to enthusiasts is unprecedented,†stated Jacky Huang, General Manager, DFI Inc. “But today the dream comes true through the collaboration from the two top notch companies in the OC industry. I believe, this perfect match will not only provide a convenient solution to the market, but also, start a new era of joint development among multiple components to achieve the ultimate performance for enthusiasts.â€
Each PC-5000 EL Platinum DFI nF4 Special module is encased in a sleek, platinum mirrored copper heatspreader to effectively aid in the most efficient heat dissipation possible. All OCZ DDR products are 100% hand-tested to ensure that their quality and performance levels are held up to stringent OCZ standards, and come backed with direct, toll-free technical support and an industry-leading lifetime warranty for unparalleled peace of mind.
Due to this timely collaboration between OCZ and DFI, the OCZ PC-5000 Platinum offers performance benefits that ensure the fastest, most reliable DDR available today.
OCZ EL DDR PC-5000 Dual Channel Platinum DFI nF4 Special
625MHz DDR. CL 3-4-4-10 .Specially designed for use with DFI nF4 motherboards .Available in 512MB module and a 1GB (2x512MB) Dual Channel Optimized Kit .Unbuffered .Mirrored Platinum Copper Heatspreader .Lifetime Warranty .2.85 Volts .184 Pin DIMM
**Special Features .*EVP®. ULN2****Part Numbers **
.1GB Dual Channel Kit PN – OCZ6251024ELDCPE-K
**OCZ EL DDR PC-5000 / 625MHz / Enhanced Latency Platinum Edition / DFI nF4 Special / Dual Channel **
OCZ Platinum Edition PC-5000 memory has been designed for ultra-high speed operation on DFI nF4 motherboards. Due to OCZ’s proprietary Enhanced Latency Technology, the PC-5000 Platinum DFI nF4 Special series is able to reach latencies as low as CL 3-4-4-10!
All OCZ DDR-625 products are 100% hand-tested to ensure compliance with stringent quality standards. Furthermore, every PC-5000 1GB Dual Channel Kit is confirmed as a matched pair to ensure flawless performance on DFI nF4 motherboards. In addition, each OCZ PC-5000 Platinum Edition module also comes with a high quality copper heatspreader with a platinum mirrored finish and ULN2 (Ultra Low Noise) Technology to maximize stability and performance.
OCZ PC-5000 Platinum DFI nF4 series modules are the very best high speed DDR memory available on the market today and offer innovative features that increase performance while providing unsurpassed stability. OCZ Platinum Edition memory modules are rated to handle up to 3.0V without invalidating the OCZ Lifetime Warranty so that performance enthusiasts can tweak their systems without worry.
- OCZ EVP® (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 3.0V ± 5% without invalidating their OCZ Lifetime Warranty.
******ULN2 (Ultra Low Noise) technology uses various printed circuit board (PCB) techniques to reduce the amount of electrical noise that is present in all high-speed ICs. This results in faster and more stable memory.
Source: ocz
