OTG/Convection Oven/Air Fryer buying advice
Looking to get a convection oven/OTG similar to one that is made by Hamilton Beach. That thing has Bake, Broil, Toast, Grill, Dehydrate, Air frying all.
The thing is that it’s out of stock from as long as I have seen it.
My main requirement is bake, air frying and grill but would be good if it has other features. You never know what you want to try in dishes.
Budget not a big issue but would love it to be under 10k and from a reliable brand. I know convection oven don’t come cheap but the Hamilton beach one fitted perfectly in my requirement.
Offline or online, both are feasible.
my advice would be to check out how each storage capacity feels like and what you require, at a store.
I have a philips 25 ltr otg with digital display , it has been great for making cakes , baking and grilling stuff.
If u plan to making larger quantities then checkout their 35 ltr model .
If you have a small family or don’t cook that often, get an air fryer (I have the Instant Vortex, Philips is also good). If you want something big (truly old school OTG types), buy a chepo oven from Agaro (have one of these as well, bought during covid and used extensively for pizzas and cookies).
Almost all the brands of OTG are essentially the same device. Until you start seeing quartz heating elements, you won’t really get any difference between brands.
don’t have anything to add but have question of my own, hope you won’t mind me asking it. i was also looking into OTG but my primary concern was heating food. maybe baking a simple cake once in a blue moon but 99% heating food.
I live alone and really don’t want to spend much on this; so my question is - are those 9ltr ones from Faber or Pigeon upto the the task ? And is an OTG as convenient as a microwave oven ? my budget is ₹2.5k-3.0k frankly.
I did have a look at Croma 2 months ago but didn’t like anything at that time. Maybe I will have a look again at some other place.
We are only 3 people. Including my 4 yr old daughter so even a medium sized oven should suffice for me. Does your oven also have air fryer?
For your heating purpose yes the small size are quite enough but you should take the microwave and not otg
No air fryer. It’s cheaper to buy a separate air fryer
The 25 ltr model is good enough for 4-5 people .
Heating element = Grill
Add a fan to this so that hot air circulates = Convection
Air fryer is basically convection but in a smaller volume, so the effect is stronger. You can easily burn food in minutes if you’re not careful. But it isn’t a revolutionary new technology by any means.
Get a microwave for this. You can buy a solo oven (only microwave, no grill or other heat sources) for cheap.
sorry but could you elaborate on why ? is there some inherent disadvantage in OTG ?
since the cheapest microwave that i can spot are 5k-6k which imo for just heating food for a single individual is a bit much.
Yes, microwave heat the food directly rather than heating the surrounding air first. Microwave energy excites water molecules inside the food, generating heat from within, which makes reheating much faster and helps retain moisture, keeping food soft instead of dry. In contrast, a convection OTG/ normal OTG heats the air and the food’s surface first, so heat slowly travels inward, often drying out the exterior before the center warms
For reheating food, inside out is always superior. This way the texture and moisture of the food remains the same.
Also would could be done in 2-3 minutes in microwave will take 10-15 min in OTG. so microwave will save power cost in longer run.
bought a 30L Borosil Prima Pro this year. its been great!
thank you for the explanation
