PC For Maya
HI every one .. i will like to some one can guide me for a good motherboard for Autodesk Maya
i was planing for asus rampage 4 extreme or asus maximus 4 extreme
and intel intel i7 2600
coz i want to Maya to be smoothe with no problem in rendering plz help
with 2 gb ram
thanks
I recently built a pc for animation and rendering work… you have requested a motherboard that would assist in rendering. I would suggest get more ram ( I have added 16GB) and if you can get a NVIDIA QUADRO graphic card that would really help in rendering.
As for a motherboard I would suggest go for ASUS P8Z68-V PRO/GEN3.
Use this template when asking for advise, Sire → http://www.techenclave.com/topic/454634-template-for-what-should-i-buy-use-this-when-asking-for-advice/.
Even I work on Autodesk Maya. Your rendering speed is going to depend a LOT on the graphics card as well as your processor speed.. 4 to 6 GB RAM will suffice more than enough. But theres no point just concentrating on the choice of your motherboard. if you’ve got a good budget, concentrate first on your graphics card and then the processor.. invest heavily on the graphics card if you want fast renderings..
Hope this helps, Cheers!!
^^^ oh yeah.. actually i forgot to mention.. GPU based rendering will have to be specifically configured. .. otherwise, the default renders in Maya will be done on the processors..
see this if you guys wanna blow your minds off with insane render speeds.. nvidia 3d boxee.. realtime rendering.. wicked..
You need to select hardware rendering instead of default render setting in maya,that way you can tweak the settings of utilizing cpu or gpu.
I am an animation student #[member=‘Jakob’] and I know a lot of GPGPU dependent render systems are available, most are optimized to run on nVidia cards and I had a HD 5770 so did not use them.
Also most established studios use CPU rendering due to the better quality of the same.
