PC not booting, Motherboard Showing Blue Light
So i after waking up i turned on my pc. The pc turned on but the display on the monitor was not coming on so i shut down the cpu by holding the power button. The next time i turned on the pc the blue light is on but pc isn’t booting. The fans are not starting or anything just the light is on. I changed the motherboard battery too. Pictures Specs : * i5 4690k * 32gb Corsair Vengance (8*4) 2400mhz * Msi z97 pro gaming mobo * Powercolor r9 280x * Coolermaster HAF XB Evo Lanbox Case * Coolermaster Masterliquid 120mm AIO * 120gb skhynix m.2 ssd * 500gb hdd 7200rpm * 750w Gold+ Fully modular psu (silverstone)
Can you check your motherboard manual for what that light means? It doesn’t look like that’s the ez debug led
try clearing cmos and reinstalling ram and check your motherboard manual for what that light represents.
