^^ Totally agree with Choas, SM3.0 performance on the 6600GT is showing its true colours and you can decide between some regular gameplay or a scenery slideshow…
I never had any performance problems with the 6600gt even at 1280 2x/4x aa in any games except nfs ug, riddick, fear and cod2 dx9.
(But then I am obsessed with quality and an average 40fps is ok with me except in racing games.)
All the above need to played at 1024 0xaa except riddick at 1024 2xQ (slowdowns over shimmer hell anyday).
cod2 dx9 gives ~30fps at 1024 0xaa with heavy drops during firefights. Under dx7 it runs like quake3 even at 1280x960 4xaa, but that’s obvious.
As for fear and nfs ug, they run like crap on most pc’s.
The latter is silky smooth once you turn off bloom and blur, but then it looks worse than nfs4.
farcry @ 1280 2xQ, character shadows off and max 3d vegetation distance : 40-90
doom3 @ 1152 2xQ : 40-50
hl2 @ 1280 4xaa : 40-70
ss2 @ 1280 4xaa, hdr off and dynamic shadows at minimum : ~50fps during seriously mad battles, hovers around 80-100fps otherwise. Turning on hdr isn’t much of a hit either.
Not played nfs mw, so no idea about that.
Using 81.85whql…
The nforce is not the graphic card drivers. Nforce is platform drivers for your motherboard. you keep refering display/forceware drivers as nforce 6/7.
If you are still using 6x.xx series then i recommend you update to latest 81.95 drivers. And update your nforce platform drivers to 6.70. Both are available at Nvidia.com download section.
If you read this articles,according to this my system should be able to play the following games at 1024768,max ,no aa/af or better:
BF2
FEAR
AOE3
Quake 4 ,12801024
Splinter Cell:Chaos Theory
Why don’t I attain these speeds then and why can’t I play NFS:MW
with no aa/af,1024*768,max
well only 1 release of NF4 platform drivers had problems and that was 6.55 or 57. I dont remember which one. The problem does was solved in later releases.
The drivers you are using are too old. Then entire 7x.xx series came and went and now we are at 8x.xx series.
Many issues related to newer games get fixed in new drivers.
Also you bought the mainstream GF6 card. It supports SM3.0 but that does not mean it will give you playable FPS in every SM3 game.
Its not just graphic card thats responsible for the gaming performance. The RAM,CPU, the memory settings and timings, how well the system is maintained, amount of junk and background services running, all this matters.
Remove the old drivers and install new ones. And next time try to ask in 1 post that 2-3 posts.
6800(16x6) means that he has unlocked the pipelines of his cards.
first thing’s first, get your forceware updated to 81.95[quote]
[/quote]
if that does not solve your problem, then we can eliminate all other possiblities one by one. lets not jump the gun.
also, as to why other tested cards are able to play, i’m pretty sure that although the cards are same, they would always use the latest drivers. thats why you must update your forceware to 81.95.
