PES 2009 for PS3 from US compatible with Indian PAL PS3
Hey guys, as the title stated, planning to get the PES09 for the PS3 from US, just wondering if I would have any compatibility issues with my PAL version of the console?
Thanks
all ps3 games are region free. it will work on your console without any issue.
only thing that might be a problem is that it might not work online if u play against someone with a pal version. i am not 100% sure about this. maybe try n google a bit. it might even work.
do let me know if u findout anything.
there is an another problem if ur not using HDMI connection.the ps3 doesnt run some games(mind it not all) if u r using component connection.it throws an error
why should there be any problem?
i have pes 2008 NTSC on my PAL console and no problems whatsoever.
i am unable to run some PAL games on my NTSC console from usa so using hdmi to run those games
Yep kris is correct. Check this thread on GI
Board Message
But dont think PES will be a problem.
