I have jointly written a guide for Gparted. As many of you know that this is the best possible partition manager and it can handle almost all sorts of file system. As the guide is quite extensive with images, I am posting the lik of the blog here (I hope that is allowed), where you may find the complete guide.
Frankly the article is quite big…and it has a lot of formatting which can not imported properly. Lastly since it contains a lot of images there are will be high band width usage. So I decided not to use extra bandwidth for the same thing which can be available elsewhere. In that way TechEnclave’s bandwidth is saved.
There is another tutorial there on Dual Booting of Linux…you may also check that out. Also check out the latest post about YPOPS!..those who use email client should find it useful.
I shall try to put up new pictorials from time to time there. If anyone here has any specific need please let me know.
