The AK400 with an additional fan in a push-pull configuration would keep your budget low and provide sufficient cooling. As others have said, you definitely don’t need an AIO but the extra fan would give you a marginal improvement.
What’s your budget ? To be honest 5600X isn’t that hot so even the cooler that comes in a box should be fine. Deepcool AK620 is an overkill for this (but it’s good to have if your budget allows it). Deepcool AG400/AK400 also solid options and a less expensive than AK620.
I’ve also liked it, color is least important for me because my PC is hidden in a wooden cabinet. Even if it was out exposed I would still not hate the color, on a different note I would not buy a Noctua because Artic beats it in all (talking about fans) specially 140mm fans.
