Looking for a small sized Power Bank with USB-C power delivery. Preferably from Amazon. Needs to be capable of fast charging (of the power bank) and fast charging of devices. Something with good USB-C PD protocols
Thanks puns. I can spend upto 2k if required.
Currently have an old gigantic 20000mah xiaomi one but it’s slightly swollen it seems so don’t want to carry it around.
I’ve used Portronics cables before but never something like a power bank or power delivery device. The 4 star rating on Amazon has me slightly worried
Im using this powerbank for 1 year with no issues. its really light. input output charge is 22.5 W.
You can also look at ambrane or duracell. Maybe go for one with more output ports.
Ignore urbn has they are heavy
This one from Ambrane seems to be on sale:
It has two outputs as well as 22.5W Fast Charging support.
I hope the OP won’t mind for with a related query. Any of the suggestions made support passthrough charging ?
Not at all.. That’s a good point.
I’m also considering
https://www.mi.com/in/product/xiaomi-pocket-power-bank-pro-10000-mah-33w/specs/
Since it lists all the Usb-C PD output voltages
Anker has some good power banks around 2k, you could check those out as well
Thanks, but unclear if it supports passthru charging
@@ibose I use older version (22.5 w) of mi pocket powerbank pro for the last 2 years. I do charge mobile using pass through charge of powerbank. So yeah, they should support it.
shargeek has passthrough. Expensive 7k onwards.
Can you share the link to buy ?
same, i just discovered slight swelling few days back (was not in use and away from sight for last 3 months or so)
you made this thread in right time.
btw better to dispose it, it nothing but fire hazard.
This is good, supports fast charging both ways but it is not handy at all. It feels bulky and awkward to hold.
I own the Mi one and OnePlus 10000 mAh power bank (currently for sale by someone in a thread here). The OnePlus feels so handy and comfortable to hold along with mobile phone. I hardly take the Mi one out with me because of this.
This one ^
Got this. I prefer the shorter but thicker dimensions. At least when compared to my old Mi power bank. This one has the benefit of easily fitting in the back pocket of my jeans. I decided against the Indian powerbanks because, at least based off the Amazon reviews, they seem to use lower grade lipo cells which result in the cells eventually bulging and cracking the case after a while.
Don’t buy mi or other power banks which only have 1 usb c ports . And 2 usb a ports which is a waste these days .
I am using spigen without any problems it has 2 usb c ports and only 1 usb type a ports comes with both 10thousand and 20thousand mah
Limited-time deal: Spigen Durable Alloy Power Bank 20,000mAh, 30W Fast Charging Power Bank with PD3.0 20W for 2 USB-C Ports, QC3.0 22.5W for USB-A Port - Dark Silver
Be careful don just buy any powerbank that says 10000mah especially from offline stores. Read all about it and if can’t understand use chatgpt to make terms simple.
My most accessories are of Anker, their products are good.
Does this support pass through charging ? Anybody?
