Please report any issues, clarifications, suggestions in this thread.
If you are reading this, do remember to reset your passwords.
Well this feels different ![]()
Couple of things I noticed immediately:
Looks decent though. Congratulations.
I don’t see anything under saved posts
Clicking on a user profile doesn’t show number of messages / number of likes. But there’s a Cheers counter. How is this calculated?
Awesome work @Renegade !
Still getting used to everything but certainly feels like an upgrade.
One issue I noticed is that when a user is quoted, their avatar image inside the quote block is broken even though it shows up correctly elsewhere.
When typing a reply to a post, if I insert an image, sometimes the preview is broken. For example screenshots break the preview but photos from my camera roll show up fine. Something related to image format maybe? In any case, the images work normally after posting the reply.
System user avatar broken everywhere.
In some places like sale threads, where a user has posted a set of images, One or more are broken. Haven’t noticed any pattern yet.
Please post some sample URLs posts with broken images. They just need to be reprocessed I think. All attachments have imported.
Where is the ‘New Post’ or ‘Whats New’ ? Lost good old TE vibe.
And what is this Side Bar, upon hiding it user lost all the navigation.
My sale thread seems to have been locked for some reason. Not sure why. I can see some sort of a flag that auto closed it or something.
At the time of posting two images on each on these sale threads were broken. Daily memes thread also had broken images when scrolling through it.
What happen to the tapatalk integration
Is it the non-lego set thread? That thread seems to be open.
Default image path of the logo is https://techenclave.com/uploads/default/original/3X/9/b/9bd1da3a9186834ff9a43e26c12e5f0ba72058cd.png
And the scrolling version is https://techenclave.com/uploads/default/original/3X/b/a/ba8642225d10ecb6378b3728be718759e631a0c5.png (which leads to 404, hence the broken image)
Regarding the images in the thread I will give an example from my own thread [LINK]
Out of 6 only 3 are loaded.
In general, the pattern I have observed is that images with URLs having a,b,c,d,e, etc (Alphabets) after [https://techenclave.com/uploads/default/original/3X/] are NOT loading - https://techenclave.com/uploads/default/original/3X/c/5/c55dd6438efaeacb795302c5f319b6ffd5be4d77.jpeg
But the ones with 1,2,3,4,5, etc (Numbers) are loading - https://techenclave.com/uploads/default/original/3X/5/5/551d633359b833b82808262544bf3fd23593424b.jpeg
My post got auto locked:
One Image broken
I can’t comment with less than 20 character
we aren’t allowed to bump anymore?
Can you please bring back ignore thread option. Also, pages of threads rendered better than the continuous threads.
As others pointed out, the images in a thread are broken.
Scrolling up works fine, it is the scrolling down one that is broken.
Check below link. This seems to have been auto locked.
It was mentioned that continuous scroll is the only option now. Best thing to do is to click on the post index at the bottom and then use the smaller pop-up to scroll, since the normal one is a pain to scroll through.
On this note, quoting by default doesn’t display the text, so I cannot delete part of it prior to posting.
