If possible this feature should be removed.
Sometimes an author wants to delete a mistake or the entire post, but the edit history feature nullifies that by keeping a visible record.
got it from
I didnāt realize that you can see the edit history for others as well. I think edit history should not be publicly visible.
@Renegade This setting can be changed from here:
@Renegade is there any way to get Senders USER ID here, instead of such tiny icons?
My ID had a space since beginning. Now its got an underscore. So seems like all previous mentions are broken.
Have you checked any post where you were mentioned before?
Username changes are changing in old mentions too.
Can we make the date format for āoriginal purchase dateā in market listings more clear? Right now when creating the listing, the format is DD-MM-YYYY but after posting, it shows MM-DD-YYYY.
Iām assuming Discourse is taking into account user locale settings and doing something. But this might cause confusion.
Has anyone experienced issues posting images on mobile? It gets stuck on āProcessing,ā even with Brave Shield and cookies turned off. Iāve also tried different browsers, but the same issue persists.
However on PC, it works like a charm even with Brave Shield on.
Works fine on default browser on iOS.
Yes, why else will I post this? Mine was a change during migration. Not just a change of username.
Same issue here , canāt find direct messages and even old inbox messages . Previously in old TE it was accessible for me.
Also my username changed for some reason previously it was āthe_dudeā . I donāt how it changed to āthe_dude1ā.
@Renegade I cannot nor @Prosenjit cannot give and take feedbacks in a sale threads Openbox items where I bought Rapoo C280 Webcam. Please look into this matter man.
Check the posts below:
Seems to be working fine. What is the issue? Post a screenshot.
Just bumping this.
Also, could we add āReason for saleā in the fields for marketplace listings?
I think it is there, but as an optional field.
Just checked. Couldnāt see it.
We removed reason for sale as it was pointless. It was discussed and voted and removed.
Regarding Heart and Likes switch. Donāt have time to test the impact. Will look into it later.
How do I quote other peopleās posts?
I need to quote a specific portion, earlier this is under reply - a preview appear. Please help.
Searching, I couldnāt find if this was discussed earlier.
