Problem with MX700
i have a logitech MX700 mouse … i have just changed its battery with 2000mAh … origianlly it came with 1700mAh …
intially it needs a recharge in around 4-5 days … i used it for around 2years and then i have to recharge it every day, so i thot maybe battery’s are gone so i got new pair (its sanyo model HR-3U 1.2v) for 250 it was open not packed … but even now i have to rechrge it everyday … and sometimes while charging the contact points gets very hot … even the lower portion of the mouse …
i went to rashi and they said it will take 15days coz they have to send it to mumbai … if i it is not solved then i will it to them for repairing
on the new batteries date of manufacture is written as 02-05 …is it 2nd month 05’ or 5th month 02’ … i am confused someone please help
Nope its Feb. 2005.
Thats odd.
It may be a Fake Battery. So that could be the problem.
Plug in your old battery and see if the points get hot.
yeah the problem is there from 3-4 months … even with the original battery contacts gets hot … it seems battery it not getting charged properly as when i put a fully discharge battery it is charginf in only 2-3 hours … :frowning:
Help Help!!!
Earlier it wasnt getting hot? Something might be wrong in the Converter of the Charger. Do a volt check.
