I needed help with the “at blah shutdown -r” command. I want the comp to restart at 2 in the night. But it hangs on the screen which says windows is shutting down. It happens only in the night. Not when I try restarting any other time. I use a batch file at startup to execute the command…
use /f to force all apps to close too . Use this instead
I used force command too… Didn’t work. Will check out the link
another way to do it will be:
create a batch file with only “shutdown -r” in it.
from scheduled tasks, schedule the above created file to execute at 2.00 am.
try this,.it has always worked for me.
