Project White Knight : Air Cooling at it's Best..
Thank you for appreciating :).
i haven’t cut the case yet,but all the markings are done & i will soon cut it.
the problem is that i don’t have access to power tools like a dremel except a drill machine.
unfortunately i will have to cut the case old school style using saw blade.
You can get a good B&D cutting tool for less than 3k shipped…
UPDATE - 21/12/2010
Finally i was able to cut the side panel.
it took me about 5 hours to cut it & file it.
i used a 1/8" drill bit & drilled some holes out then i used a saw blade to cut it & after filing it here’s the result.
i think it’s almost perfect.
what do you guyz think??
this my friend is truly awesome
cheers bro and keep it up and keep us posted :slight_smile:
Thanks Man. :slight_smile:
even i’m more than satisfied with the results..
thats pretty ooooooooooooooooooooooooosome :0
Thanks Man :slight_smile:
UPDATE - 26/12/2010
Got some free time to work & completed the top panel. :slight_smile:
i used a 1/8" drill bit to drill a series of holes inside the line,filed it & then sanded it to make it look professional.
here’s how it looks like -
so,what do you guyz think??
will start preparing the outer panels for the case for paint from now on :slight_smile:
I must say, you are a man of extreme patience :grinning_face_with_smiling_eyes: Great work, would love to see the final result :slight_smile:
^ Thanks :slight_smile:
thats preety accurate cutting dude :wink:
i like doing things slowly,but with perfection :face_with_tongue:
UPDATE - 30/12/2010
I Searched for a Professional Painter in my city & came across one.
the outer panels are now sanded & primed using Self Etching Primer
here are some pics (two to be precise :face_with_tongue: )
apologies for bad pic quality :ashamed:
why a green colour?
Superb work hats off to you. The cutting job is excellent…so u actually just drilled a couple of holes and then used a band saw? Wow, hats off buddy. And I hope thats the primer coat.
Man that’s really cool
@ surajspai - i don’t know buddy.i suppose different brand primer are of different color.
@mav2000 - Thanks,it’s an honor being appreciated by you. yes,it took me some time to make holes in top panel but i did it with patience & filing was comparatively easy as it’s aluminum not steel.
@Vibu - Thanks :slight_smile:
**NEW YEAR BRINGS NEW UPDATES :face_with_tongue:
I WISH ALL MY FELLOW TEians A VERY HAPPY & PROSPEROUS NEW YEAR
UPDATE - 01/01/2011**
Before modding i used to see others projects on sites all over the world & i found one thing common in them.
can you guess what was it?
PETS
people said that they are always there when you are modding something but i didn’t believed it, UNTIL NOW
This is a very small update to be honest,anyways here it goes
after priming the panels,he used a soft kinda filler to level the surface which i screwed using drill bit. :face_with_tongue:
hope you all guyz like it :slight_smile:
UPDATE - 04/01/2011
After sanding the filler a bit he applied Surface Primer to all the panels.
here’s how it looks after the job :wink:
**UPDATE - 09/01/2011
THE CASE HAS BEEN PAINTED WHITE,HERE ARE SOME TEASER PICS
I’M A HUGE FAN OF PINSTRIPING ART BUT SINCE THIS BEING MY CITY WHICH IS MORE OF A VILLAGE I DECIDED TO USE PLOTTER INSTEAD OF PINSTRIPER :wink:
The black part is Stencil on which i’ll be painting up tomorrow. :face_with_tongue:
BEHOLD THE BABBAR SHER :clap:
