PSU Pin Removal Tool
Does anyone have one that they can sell me? I would like to re pin my sata power cables from 5 pin flat to 6 pin rectangular connectors.
The stapler pin method isnt working well.
Repost the image and be clear as to what you are trying to do.
I want to remove the pins from the psu side connector of a sata power cable.
I want to get the tool in use here in this image. Does anyone have one?
I used to remove these easily using a very fine screwdriver.
I tried stapler pins but it was a mess.
Lol! what? Whats logic you thought using them?
Its a well used DIY method. Saw videos which did them relatively successfully. I was much worse at it.
Screwdriver idea may work but will need some wrist watch sized tools. Paper pins may work but they are too thick & round.
You should try using pins from larger staples. Ive never had problems with them, only the smaller/regular ones
An extremely good idea. Just the right size without the fiddling. I used the smaller ones. I was thinking of what might be the correct size. But didnt think of this. This sounds perfect. Let me scrounge & beg for a few pins.
