^^I have a cheapo pinnacle and it does have composite in. As long as ur 7900GT is VIVO, u can use ur video card. However there’s a fairly small chance of that… most of them only had TV out, no input.
the 50i has these specs, since it has a composite in, that should work right?
and can the audio out from it can connect directly to the audigy2?
* Video Inputs: S-video, Composite video (RCA socket, via included adapter)
* Audio Outputs: 2.5 mm header (internal)
* Stereo audio support: Audio cable for connection to a soundboard or via PCI audio streaming
* TV signal: IEC connector (PAL/SECAM)
* FM radio signal: IEC connector
Yep, thats the image i had looked at earlier and commented. However as per what you posted:
So an adapter would be included for S-video ↔ Composite . If not i think it shouldnt be a hassle getting such cables, i remember one being included with one of my previous graphics cards.
