Hello folks, I copy pasted this from @Prowler_25 :). Thank you!
I need recommendations, suggestions for building a multi-purpose PC for Gaming primarily, but also coding, AI, streaming and YouTube content creation.
[*] What is your budget?
- *<*3L
[*]What is your existing hardware configuration (component name - component brand and model)
SSD - Samsung Pro 4TB SSD
RAM - GSkill 2x16 GB
[*]Which hardware will you be keeping (component name - component brand and model)
RAM - Gskill 2x16 GB
[*]Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
Motherboard - ROG Strix X870E-E
CPU - Ryzen 7 9800X3D
GPU - AMD RX 9070 XT 16 GB
CPU Cooler - DeepCool AK620
PSU - Corsair RM1200x Shift 1200W
Monitor - Samsung Odyssey OLED G80SD 32.0" 3840 x 2160 240 Hz
[*]Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
- Yes, final 10 year build
[*]Where will you buy this hardware? (Online/City/TE Dealer)
Online - excluding Amazon
Open for Second Hand
[*]What is your intended use for this PC/hardware
Coding
Gaming
Streaming
ML/AI running LLM locally
Video Editing
YouTube video production
[*]Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
- None, but I’ve mostly used ROG in the past
[*]If you will be playing games then which type of games will you be playing?
- Most new and old titles in FPS, RPG, TPS, Narrative games, Indies etc. I like playing a variety of titles. Baldurs Gate 3, Stalker 2, Witcher 3, Clair Obscur, Hollow Knight, Alters as examples.
[*]What is your preferred monitor resolution for gaming and normal usage
- 3840 x 2160
[*]Are you looking to overclock?
- If needed
[*]Which operating system do you intend to use with this configuration?
- Linux/Windows
Want to build a system that will mostly last 5-10 years. So need to design a system with upgradability in mind for evolving needs.
