Hello everyone
I have pc and laptop and both of them connect to the internet by router
i want to control of the pc from the laptop how I do that?
thanks for the help..i
Radmin or VNC
**UltraVNC is a powerful, easy to use VNC client, that can display the screen of another computer (via internet or network) on your own screen. The program allows you to use your mouse and keyboard to control the other PC remotely. It means that you can work on a remote computer, as if you were sitting in front of it, right from your current location.
If you provide computer support, you can easy access your customer’s computers from anywhere in the world and resolve helpdesk issues remotely ! With add-ons like SingleClick your customers don’t even have to pre-install software or execute complex procedures to get remote helpdesk support.**
VNC you can get it here…
I need the software on the pc and on the laptop or only on the laptop?
is it free?
just use windows remote desktop no need to install anything.
yes i tried with windows remote desktop but i couldn’t connect
it gave me error massage i think it because that my pc and my laptop have the same ip here the error massage:
you must first enable remote desktop on ur system so that another system can connect to it google for it (cos i think u using vista and me dunno where the enable checkbox is
so like u want to control ur PC from ur Laptop,right? so u need to enable remote desktop connections on ur PC so that it ll accept the connection from your laptop
yes i did that i allow on the pc and on the laptop the remote.. and the error massage steel shown
Remote Admin !!
It is very simple and Effective !!
Try VNC.
Simple & effective.
VNC installation, configuration and use with Linux and Microsoft Windows
external firewall? etc? dunno why. ideally it shud connect.
This should work fine
CrossLoop - Simple, secure screen-sharing and trusted experts for computer help
its work with logmein
thank you everyone!
Congrats !!!
