Replacement ear cushions for razer kraken x
Hi guys,
My current headphones razer kraken x have been working fine, but the ear cushions have been falling apart. Is there any where I can get new ear cushions for the same? Current ones are really good but the leather or resin or whatever it is, is coming off.
Thanks for your help.
Did you try checking brainwavz? Look for the size and compare the shape. I got pads for my Razer Electra too. Had to buy the Logitech version but dimensions were same and they fit
It cost 1200!? Bro my headphones cost 4000 I cannot afford that much for just cushions. Any cheaper ones?
No idea about cheaper but these pads are much much better than any pads. They feel like pillows on your ears lol
I don’t doubt it. Looks high quality.
Sadly, headphones are made in such a way that you need to replace them after certain amount of time due to cushion wear.
If companies made cushions available on mass scale then nobody would buy headphones anymore.
