Can I use my Samsung 25watt charger with iPhone 14 or it has to be Apple charger?
you can use samsung adapter, no issue. if it supports PD then you can even fast charge.
Yes you can. No issues.
No issues,if any charger supports the PD then it can be used.
you can use but expect painfully slow charging times. Strongly recommend using Apple’s charger to charge Apple devices.
Nope…i myself use a Gan PD charger for iphone and it charges it at max it supports…mine is iPhone 12 mini so speed is slower than bigger models
