Samsung phone with dedicated sd card slot in 15-20k range
All the ones I looked for are hybrid sim slot ones, preferring samsung because of samsung notes (the person already has a samsung tab with stylus). Onenote on android kind of sucks.
Cant even find any phones with dedicated slot in the 10-15k range either
Why do you need dedicated sd card slot? Is it because with dual sim you can’t use sd card?
I bought a samsung m13 about a year ago and it’s a slow piece of !@$@#%$ shit. (had a moto g5 and redmi 2 before)
I’m never going to buy a samsung phone again and recommending the same to everyone else.
@@Heisen yes, need to use 2 sims and sd card simultaneously
@@Crapmypants Its going to be used lightly, just regular phone usage and social media apps etc
[Samsung Galaxy F14 5G](’
https://www.flipkart.com/samsung-galaxy-f14-5g-goat-green-128-gb/p/itm032d1a69999cc
Just buy this, wrap it around put a case on.
@@rajanmehta thanks for the suggestion, but the buyer specifically wants something around 20k price range (don’t ask me why). Also the price seems too high, a friend had bought the same variant for around 9k last year . I had looked up its current version - the F/M 16 but it seems they only have hybrid slot from F15 onwards… sad state of affairs really
@@Heisen I did not know that such a contraption existed ..had to use image search to find out what it is. Have you used this thing with your phone? Online reviews seem to be mixed, some saying it doesn’t work, some saying it works well.. The buyer is not that tech savvy to make use of such a workaround, but thanks for the suggestion. You learn something new everyday!
I tried it once and it worked, I didn’t use it for long time. The only problem I see with this is, if you need to remove SD card or sims or the case on regular bases, then I suppose it won’t work reliably, as long as the contacts are making contact, I don’t see any reason to why it won’t work.
The flex cable is flimsy, it will be squeezed into the sim tray, if loaded once and not removed it should work.
Phone drops shocks or vibration may cause this to not work, depending upon how tight the case is, if that holds it nicely it shouldn’t be a problem, there will be a ugly bulge on the back of the phone though.
This is a hack job, but it’s nothing complicated in nature. Using this we are just tapping into sim contact points.
Depending upon the phone we might have to add padding in between with a paper in sim tray, so the contacts stay tight and solid. The adapter is just for SIM, so there is not a huge data transfer thing going on, it either will just work or not.
If you don’t find a phone with dedicated SD card slot, this is the next option.
Hmm thanks for responding, will see if the moto 60 stylus seems agreeable to them, has a sim+esim+ sd slot
