Secondary or third monitor advice
I have a 34 inco qhd 165hz MSI UW curved VA monitor connected hung in monitor arm, connect to 4080 super, windows pc. Its decent, i like the immersion.
I’m also getting a Mac mini m4, so i definitely need a second monitor.
I have ordered a LG Ultragear Gaming 27 Inch Full HD VA Monitor 165Hz, 27GQ50F
https://amzn.in/d/0WfJmWK
on order for 7400.
I think the price is cheap but also , this monitor is not good.
Together i think this will be jack (34qhd average monitor) + a** (27fhd) setup.
Should I avoid this 1080p 27 165 va monitor and instead get a portable 16inch fhd monitor right now and later add a 4k monitor later?
I think a 34qhd + 16 portable + 4K low refresh rate but good colour accuracy for mac would be better.
I might have answered my own question, but is the monitor on order totally useless for me? I should mention that all the 16 inch monitor I see available here in india are 10k plus.
Or maybe something else from your own personal experience.. help me out here
I should first say i have no personal experience with high-end monitor.
Assuming you are getting a mac mini for things that require more pixels and a color accurate picture, you might consider 1440p or 4k, with high contrast ratios and NTSC ratings.
But for normal work things that don’t require monitors accuracy, getting a cheap 1080p is a good option for saving money, especially from the things you don’t need.
But the portable monitor sounds pretty bad, unless you will **use it often **after buying the 4k monitor, its just seems like a waste of money. Its difficult to find usefulness in it.
Yep I would recommend against plain 1080p Full HD these days… if you can’t get an LG 4K 27 inch IPS now, then portable unit is a good stopgap temp option. I have done the same, I got an MSI portable monitor - it was quite handy - now that I have a 4k monitor - I keep the portable one for backup or maybe to connect to my miniPC / Rpi etc if I need.
This one is what I got →
https://in.msi.com/Portable-Monitor/PRO-MP161-E2
I had this monitor for a short while, it uses a horrible panel. Poor color gamut. I think it is sub 60% srgb and some 600:1 ratio. Saying this cause OP mentioned accuracy. Regardless of levels, this monitor is bad for even basic media consumption. For spreadsheets, emails and that kind of work, it is fine.
OP, you can check out Arzopa monitors if you really want a portable monitor. Good colors. But consider it to have zero after sales. They’re all pricey for what they are though.
Don’t buy a regular 4k monitor for the Mac Mini, buy a better suited monitor that has aspect ratios that are supported by the Mini natively. I have an M4 mini, and a 4k TV connected and everytime I switch from Windows to Mac, I cringe.
You can also consider buying a KVM switch so that you can use the same monitor and peripherals for both the mac and the PC.
I think you have very high standards :grinning_face_with_smiling_eyes: this monitor is quite good for regular use, even videos are acceptable, especially when this is a stopgap/temporary and not long-term daily driver unit. I was pretty impressed with it. Can’t compare it to a proper full sized monitor which will have a better panel of course. This is IPS too but only 6-bits panel hence looks like why you find it “horrible” compared to whatever you’re comparing with. Worth it IMO (pretty VFM) for around the ₹11k that I got it for a few months ago.
I guess this is what OP wants for the eventual monitor not for the stopgap portable unit.
Its not about standards, it objectively is not a good panel. Black is like blue-grey, skin tones look awful, red is a weird mix, poor contrast.. etc. If its acceptable to you for your purpose, that’s cool.
I’m comparing it the other options in the market. I have tried most of the options out there (had this, Cocopar and Arzopa). For a little more you get a far superior panel from other brands. Portable monitors are overpriced anyway, and I don’t think there is such a thing as VFM. Ironically, imho the MSI monitor offers the lowest VFM of the lot.
Anyway OP, apologies for derailing the thread.
@@tr27 On another note, I know from friend’s experiences and general reading that Mac UI is optimized for 5k and not 4k, in case that matters to you. Lots of videos online demoing this.
Also, from my experience, 4k on 27" isn’t optimal. You’d have to scale to 50% for readability and ample window real estates, which makes it pretty much 1440p (not considering pixel density). 4k on 32 inch is good. Just some additional things to consider.
hmmm perhaps you got a bad unit? anyways yeah let the OP figure out what they need.
I have used 27" 1080p monitors in my office, its lower pixel density is easily noticeable for me (my main monitor is 27" 1440p). Buy 24" 1080p or 27" 1440p (will cost 13-14k).
there are uses.. like a wiki page/discord/youtube while doing something on main.
noted , so 32 4k or higher of mac mini?
but the msi good for what it is , like a secondary for a info page or discord
i rejected the 27 inch monitors.
i got this, but not the e2 , the older one, 2nd hand. i wish i had gotten the e2 because of the ability to screw in. i am still on the lookout for the e2 on used market
i think i made the right decision, the portable monitor saves me desk space, runs on only 1 type-c cable, maybe saves some electricity as well.
im actually thinking about getting another portable monitor , a 4k this time.
also high jacking my own thread to ask everyone’s opinion about using this
https://www.amazon.in/dp/B0D9YBVLKT?ref=ppx_yo2ov_dt_b_fed_asin_title
as mic arm? when not used as mic arm, it can be repurposed .. but is it going to be decent mic arm?
I initially got the MSI E2 for the same reason- to use the 1/4" tripod mount.
I wouldn’t hold my breath in the hopes of finding a portable monitor on the used market though- its such a niche item.
And about that desk clamp, it looks perfect. I’ve used Digitek’s tripods and other accessories for music equipment, and if the quality of that stuff is anything to go buy, this would surely be fantastic as well.
Would definitely avoid the LG ones, its pretty terrible in every regard (other than price maybe). And 1080p at 27inch is just not good. Would recommend 1440p at least at that size.
I personally use a 27inch 1440p 100hz as my secondary (which I’m looking to sell actually, PM if interested :)). And it works pretty well for all the text heavy stuff I put on it. If you have the desk space for it, you can just keep it as your secondary screen even after getting the 4K one.
As for the portable monitors, they’re just always gonna be pricey for anything decent in India. I’m guessing you want it to carry it with the Mac mini?
