Sennheiser PXC 550-II Wireless ANC Headphones
Product Info:
Works great. Battery life well over 20+ hours though I have never measured it closely. However, a charge lasts me the entire week when using it exclusively through the week, so I would say the battery life is probably more.
ANC works good, though not at the level of Bose/Sony. The sound quality on the other hand is great and perfectly neutral. Supports multipoint and has support for aptX, aptX-LL, AAC and SBC codecs. It also acts as a USB DAC which most headphones don’t support.
The earpad cushions are a bit worse for wear though as visible in the pictures. However, like any other Sennheiser headphones, it is possible to change the earpads.
It is no longer in production, though it sold for 15k just last year, so have depreciated it accordingly.
Price update to 7.8k + shipping
7.7k + shipping
7.5k + shipping
It is easy to remove the ear cushion and replace it. eBay has it for less than $6 and you can find it locally as well for more.
Withdrawing from sale. Will continue using it with replacement pads.
