Smart/Android TV or Android Box with Monitor
hello,
someone has asked me to suggest options in smart/android tv, within a very limited budget of 10-12k. i advised an android box + a monitor as an alternative setup (both, used). could anyone pls suggest which of the two would be better in terms of cost, useability, life etc.?
and any suggestions on the models themselves pls, for android tv & boxes for that budget? mi tv, acer, toshiba etc. come to mind.
thanks.
That is a pretty limited budget. You can only get the lesser known Chinese TVs although I doubt if any would even be FHD. If lucky you may be just able to find used FHD Monitor and android stick/box in Olx.
A better option, if possible, would be to just use the existing desktop/laptop and the streaming apps/browser
Online Fashion & Lifestyle Shopping for Women, Men & Kids in India - Tata CLiQ :confused: &s_kwcid=AL!856!3!563789887420!!!g!1515557759989!%7bkeyword&&cid=ps:E_sok-TataCliq-STD-TV-Entertainment-Visits:Google :face_with_tongue: LA_Electronincs&gclid=CjwKCAjwo8-SBhAlEiwAopc9Ww3mZSiJ-tGnuUCkHK9mLVFQAiRf5MqLrdYgnyDLgTX6xQEXWt9XahoCRJIQAvD_BwE&gclsrc=aw.ds
You’ll only find 32" 720p TVs in this range from Mi, Realme, VU etc. I’d go with above VU model.
Alternative route would be to buy a used fire TV stick/Mi TV stick and get a 1080p 22-24" FHD monitor. I suggest minimum 32" for TVs otherwise you’ll have to watch from near distance.
i thought thats the budget for an android box, monitor excluded…
His budget is low
It’s better to get a HD Android TV than to go with a separate monitor and firetv stick likewise
Really depends on his preference if one’s keen on getting 1080p and doesn’t mind lower screen size of 22-24" then it’s fine.
For just a TV purpose I’d go with 720p 32" smart TV too though as I said already.
infinix 32" tv on offer - Rs 12k ; not sure about quality. one should see reviews before placing order.
https://www.flipkart.com/infinix-x3-80-cm-32-inch-hd-ready-led-smart-android-tv/p/itm2747cfb0067f9?pid=TVSGCY74FUKAEZDX
thanks. the laptop is being used by the kid so it wouldnt always be available to be plugged to a monitor. hence i was thinking of either they should get a tv, or a monitor+android box (both the appliances, used).
the viewing-distance anyway wouldnt be large. 4-6 ft. i believe.
the android stick also sounds to be a good option.
what if the monitor & the android stick/box are had used? possible to get both in under 12k then? the monitor though then should be 24-27".
If monitor is used, you also need sound bar/speakers apart from firestick, do consider its price too.
For Smart Tvs at that low price, navigation across menus and apps will be very sluggish, so non-smart TV + firestick will be better.
For the TV, have a look at Croma TV (Online Fashion & Lifestyle Shopping for Women, Men & Kids in India - Tata CLiQ)
thanks. agreed.
though forgot to update..the said relative already purchased a smart TV in his budget from flipkart few weeks back.
Your relative did exact opposite of my relative did, he was in same situation so as he saw me upgrading my 27’ monitor to 42’ TV he grabbed the monitor, took old speakers from his age old desktop and purchased an android box. I would say he did a great job spending only 1500rs on an android box and making a full TV
what android box for 1.5k?
No idea, he called someone who told that you can get a new one for 1.5k so I am assuming it will be most basic entry level product
The unboxed Chinese Android (not TV) boxes without any certification are usually available for that price.
