Smartphone Recommendations: Battery & Camera-Oriented
Good morning!
I’m reaching out to the mobile tech experts here for some advice.
Note: I’m aware of the general smartphone recommendation threads, which I’ve already checked, but given the length and specificity of my needs, I thought it would be better to create a dedicated post.
[HEADING=2]Background:[/HEADING]
I previously owned a Huawei P9, then a 2018 Galaxy model (whose battery lasted just 4 months), and I currently use a Xiaomi Mi 9T. I’ve grown tired of smartphones that, right out of the box, last a couple of days on a single charge, only to see the battery life plummet drastically after the first software update. This has happened with all of my devices, despite following best practices like avoiding full 100% charges, using dark mode, and other battery-saving measures.
While I do use power-hungry apps like Chrome and Instagram frequently, I consistently notice that the Android Operating System itself is always the biggest drain on the battery – and by a significant margin!
Here’s a fresh battery usage graph from last night on my Xiaomi. The situation is really dire. Even with battery-saving mode enabled, screen brightness set between 1% and 10%, and minimal usage, I often see the battery drop from, say, 95% to 45% in just about an hour. Again, that’s with very light usage.
[HEADING=2]Ultimately I’m in the market for a smartphone with a well-optimized OS that won’t degrade the battery life after just a few weeks of usage.[/HEADING]
The second most important factor for me is the camera. As a photographer, I’m possibly looking for a smartphone with a high-quality camera that can serve as a substitute when I don’t have my DSLR with me. The camera on my current Xiaomi Mi 9T is decent, but its low-light performance leaves something to be desired (which I was aware of before purchasing it).
For my next smartphone, I’d like the camera quality to be at least on par with the Mi 9T and have video stabilization. I don’t care about having a ton of megapixels; I’m more concerned with the quality of the sensor.
https://www.kimovil.com/en/compare-smartphones/f_min_d+eurPrice.150,f_max_d+eurPrice.800,i_m+code.Global:Intern,f_min_d+frontCameraResolution.40,f_min_d+rearCameraResolution.20,f_min_d+batteryMah.4500
) but since I’m not an expert, I’d rather seek advice from those with more experience, especially considering the overwhelming number of results.
:red_exclamation_mark:I’m also open to considering iPhones, despite their prices, as iOS, being a proprietary system, tends to offer better OS optimization and therefore more efficient battery management.
[HEADING=2][/HEADING]
If you could recommend some smartphones that meet the requirements I’ve outlined, ideally suggesting models across the low-budget, mid-budget, and upper-mid-budget, I would greatly appreciate it. This would help me better assess options based on both features and price.
A website I use to compare devices.
No one?
low budget: pixel 7 (30kish) but shit battery life
a little above that: S23 (good-decent battery life) @40k currently on fk, we have a couple of them on sale including mine (just a disclaimer) for cheaper price
mid level: OP 12 - not sure how the camera compares for it but range is in 60s.
mid level: Xiaomi 14: stellar all rounder with a better camera than OP 12, wont be as battery optimized
High Level: S23 Ultra @75K, S24 ultra, S24 plus and the pixel 8 (again shit batt life)
and then comes your usual iPhones but I wont claim them to have a stellar battery life
[Xiaomi Mi 9T](’
Xiaomi Mi 9T - Full phone specifications
) came out Jun 12 2019.
Assuming you bought it a year or so after. The battery is shot.
Go change the battery if the phone is still good enough for you.
Does not happen with Samsung.
If you consider models a year or so back assuming not current then it should not be hard to best your Mi’s camera not merely match it. For this you should consult gsmarena and look carefully at their photos to assess yourself whether s prospective camera is good enough for you.
I can only speak of phones i have. My first choice was LG because they had good cameras. But they stopped making phones so I switched to Samsung and currently have a S20FE & S23.
Camera and battery on these have been fine. But the S+ variants of galaxy if available and affordable should be considered if battery matters.
20k - Nothing Phone 2a 8/256GB - it will outperform 9T in all aspects
28k - OP Nord 4 8/256GB maybe
40k - S23 8/256GB (great for compact phone lovers but battery life is not as good as others but is still considered good, better than S23FE, etc)
75k - S23 Ultra
Check GSMArena reviews
2a camera is this good? damn didnt know that.
just one thing, 40k is for 128 variant on fk
2a camera is inferior to my S20FE, but not by too much, used them side by side. I’m pretty sure 9T’s camera is much worse to my S20FE, Xiaomi’s cameras were no where near Samsung flagships those days, so forget a mid range phone coming close to S20’s cameras.
S23 256GB was 40k on sale few weeks back, now is 43k or so after card discount, my bad, didn’t check the increased price.
Move scaling to 12MP under the 9T.
9T loses details in the shadows compared to 20FE
Yes, price quickly increased on those 256GB models once the weeklong FK sale ended
256gb lowest price 42k afaik. otherwise woulda gotten that for my father
If going for Pixel 8 then go with the Pro models only. Small version has a BOE panel (in majority cases) and that’s an awful panel almost unusable. Camera isn’t that great due to inaccurate auto white balance at night time, not on iPhone 15/16 level anyway , but still excels at day surpassing everything else.
PS: battery backup of the P8 isn’t bad by any means btw. Getting solid 8+ hrs even with some 5G usage.
You should aim for the iPhone.
I’ve seen your post about bad legibility on the smaller Pixel 8 and it confused me. The S23 is similar in size to this pixel 8 smd I don’t have any such legibility problem with it and that’s coming from a larger S20FE
Yes I’ve seen that Samsung doesn’t have any problem wrt to text size/scaling. I’m sure they offer a finer control over font size compared to only 6 steps offered by Google. It’s either too large or too small.
nope same bullshit just more presets
Well. Eight or one more to your seven (not six) but I’ve not needed it.
I’ve not changed the defaults for font size other than to have five icons across in the quick panel, home screen and app drawer. And the settings are the same across the two phones. A couple of hours reading on the S23 and no problems.
Experiment with a different font, the one you have is very thin compared to Samsungs default. I don’t find it very legible in either of the two sizes you have there.
You could also experiment with visibility enhancements in the accessibility section. I haven’t changed anything there.
@@blr_p There’s no other font to choose from other than the lone default font offered. Yeah. Lol.
There’s nothing wrt to visibility in accessibility section either.
The default font is way too small. +1 is probably a bit too large but I still like it. Problem is so many texts in so many apps are cut off even at just +1.
