**Product Name:** SOLAKAKA SM600 Wireless Gaming Mouse,Tri-Modes BT & 2.4Ghz Rechargeable Mouse Wireless,8000DPI,Honeycomb Shell, Side Buttons, RGB Mouse
Price:
₹399
Link:
Price:
₹399
Link:
Thank you for this.
Wanted a wireless mouse with inbuilt battery for cheap.
This should be good.
yaar I ordered it but reviews are mixed and according to the price mentioned by someone this often goes Rs 499.
So Anyone has this? can share your experience? or can suggest something in same price which is bluetooth and inbuilt battery.
450 is the correct price for this mouse, I have the wired version of this mouse, I got it for 140 rs.
5 Million clicks buttons means consider it lucky if it survives more than 1-1.5 years without developing double click issue. For reference, Evofox Blaze comes with Huano 10 million clicks rated switches/buttons & currently selling for around 580.
Posted after keepa notification. For Rs. 399 seems good enough for office use and as a spare. If you’re going to get it for gaming then it’s not recommended (especially for FPS).
If someone has a requirement for a office mouse or a spare with tri-mode connectivity then this should fit the bill. These are listed every now and then.
