Some Secret Code of Android Phones & iPhones
**Hello Guys,
Here I presents some codes for you to discover some secrets of your Android devices or Apple devices. Just put that code on your Dial pad and see it yourself.
For Android Phones**
1.#06# – IMEI Number
2.27673855#– Factory Reset Code(Removes all phones Data)
3.
##4636##* – Phone and battery information
4.##273282255663282*## – All the media files will be backed up
5.##197328640## – Service Test mode
6.##1111## – FTA Software version
7.##1234## – PDA & firmware version
8.##232339## – WirelessLAN Test Code
9.##0842## – Back lights and vibration test code
10.#12580369 # – Software and Hardware Information.
11.##2664## – Touchscreen Test Code.
12.* # 9900 # - System Dump Mode.
13.#9090# – Diagnostic Configuration.
14.
##34971539##* – Camera Information.
15.#872564# – USB Login Control.
16.
#301279# – HSDPA/HSUPA Control Menu.
17.#7465625#– Phone Lock Status
18.
##7780##* – Restore factory settings, all system data including the Google account, will be delete.
19.27673855#– Internal and external data formats, including factory setting will be deleted And the firmware will re-install.
20*##4636##* – Phone and Battery Information
21*##273283255663282## – File copy screen, all images, sound, video, voice memo can be backed up.
22*##197328640##* – For changing settings Service mode code, a variety of test.
23*##7594##* – This code and the call / power button to turn the power off button.
24*##8255##* – G Talk Service Monitor Code
25*##34971539##* – Camera Information, Camera firmware, Do not use the Update option. The functions of your camera will be closed.
W-LAN, GPS and BluetoothTest Codes:
26.##232339## OR ##526## OR ##528## – W-LAN Test Code, Use the menu button to start test
27.##232338## – WiFi Mac Address
28.##1472365##- GPS Test Code
29.##1575## – Another GPS Test Code
30.##232331## – Bluetooth Test Code
31.##232337## – Bluetooth Device Information
32.
##0588##* – Proximity Sensor Test
33.##0*## – LCD Test
34*##2664##* – Touchscreen Test
35.##2663## – Touchscreen Version
36.##0283## – Packet loop-back
37.##0673## OR ##0289## – Melody Test
38.##3264## – Test RAM version
For iphones **
iPhone Codes: Network & Phone Information
1.3001#12345#- Opens up the “Field Test” settings on your iPhone, which allows you to see many, many advanced network settings on your phone including cell site information and more.
2.#06# – Displays your iPhone’s International Mobile Equipment Identity (IMEI) number (this code also works on many other phones).
3.
#21# – Displays any call forwarding settings enabled on your iPhone.
4.*#43# – Shows you if call waiting for various parts of your phone are either enabled or disabled.
5.*#30# – Shows you if you have the call presentation (to see who is calling you) setting enabled or disabled.
6.*#33# – Displays call barring settings for your iPhone, and weather they are enabled or disabled.
Any command can be preceded by *#, **or ##.
# is INTERROGATION.* is SETUP.
is CANCEL / DELETE.
12.#500578283#-This dumps a baseband log in /Library/Logs/Baseband/ - Note 1
13.**500578283#-This dumps a baseband log in /Library/Logs/Baseband/ - Note 1
13.1.##5005
78283# -This dumps a baseband log in /Library/Logs/Baseband/ - Note 1
14.#500562#-“Error performing request - No Network Service” - Note 2
15.#500562255#-“Error performing request - No Network Service” - Note 2
16.#500587223#-“Error performing request - No Network Service” - Note 2
17.#500586#- Displays the Voice Mail dial-in number.
18.**500586VOICEMAIL# Sets the Voice Mail number to VOICEMAIL (international format).
19.##500586# -Erases the Voice Mail number from phone.
20.
#50057672# -Display the SMSC Setting.
21.**5005
7672SMSCNUMBER# -Sets the SMSC to SMSCNUMBER (international format).
22.##5005
7672#-Erases the SMSC number from phone.
23.#500522#-“Error performing request - No Network Service” - Note 2
24.**500522# -Unknown. Displays “Please wait”; returns to dialpad - Note 2
25.##5005
26.#50055264# -This reads LANG and tells you the “actual language” (en).
27.#5005#-“Error performing request - No Network Service” - Note 2
28.##5005
22*12345678#-Function unknown, displays “please wait”…; power-off to exit.
29.“#31# number” to hide caller id(to call and not show your call number) ’
Note 1: It may be necessary to change the prefix from the set of (*#, **, ##) to
initiate a new log dump. The logs are not “tail” able, since this is a single
dump, with no additional data written. So far, these logs appear to always
remain the same size. Logfiles are stamped with the current date.
I think it will be helpful for all android & iphones user…
Source
First mistake, should say
*****#06#
to know more about USSD structures, read this.
Bet 95% of the codes for androids will not work, Did u even check these before copy pasting them ?
edited
From the link in my previous post..
The UE (User Equipment) shall support the MMI (Man Machine Interface) procedure specified as:
Activation : SCSI#
Deactivation : #SCSI#
Interrogation : #SCSI#
Registration : SCSI# and **SC
SI#
Erasure : ##SC*SI#
This structure consists of the following parts:
  • Service Code, SC (2 or 3 digits);
  • Supplementary Information, SI (variable length).
The procedure always starts with *, #,**, ## or *# and is finished by #. Each part within the procedure is separated by *.
The service code uniquely specifies the Supplementary Service, either as a defined Supplementary Service or as a spare service code. All spare service codes shall be reserved for future use.
The UE shall determine from the context whether, an entry of a single *, activation or registration was intended.
*SI# shall be entered in any of the following formats:
  • SIA * SIB * SIC #
  • SIA * SIB #
  • SIA * * SIC #
  • SIA #
    • SIb * SIC #
    • SIB #
      • SIC #
And source OP?
added
