I’m planning to get either the Sony XM4 or XM5 headphones during the ongoing sale.
If anyone is using either of these, I’d love to hear your review. Also, if there’s a better option available under 25K, I’m open to suggestions.
Bose Qc 45 for better mic and long usage comfort. ANC is almost same as XM4/5
XM5 was not at all comfortable for me.. the ears kept getting warm/heated. However i think there build quality is slightly better.
discontinued
yeah hate this
The current model is simply called QuietComfort. I had purchased it earlier in the year when it was available for 16.5k and have no complaints for that price. If I were to nitpick, the codec support and battery life are the primary cons. However, it is much more comfortable than any headphone in XM series.
I have the qc45, balanced sound profile and super comfortable. Suggest checking out this review for xm4 vs xm5 [[link](’
https://youtu.be/6WTHBCZBt_E?si=AycrxyGRenTB_lXe’
I’m using buds with earmuffs on top. Earbuds could be wired to keep the costs lower
The clamping force of xm4, xm5 is 0.8 to 1lb
The [3M](’
) [earmuffs](’
) have a clamping force close to twice that. And it shows with how well the higher frequencies are toned down. You get used to the clamping force after a while. Having the volume halved is great.
using xm3 going great, you should consider xm4 more for the portability. could not find a major upgrade from xm3 to xm4 so im still at it. still amazing.
