Soundmagic MP-21 vs PL-30 for mobile ?
hello everyone..
I am a little confused to choose between soundmagic mp 21 and pl 30
mp 21 (700 rs ) - with mic - but has L shaped pin..
my samsung wave has socket at the top.. so I am little worried if the wire gets cut when I put in my jeans..while driving..
pl 30 (900 rs)- it has a straight pin
though it doesn’t have mic, my phone take builtin speaker if I use earphones.. so not a major problem..
also suggest me if there are any other good ear phones in this range.. 900 is the my limit..
Thank you..
pl30 would suit you fine mate.i use it most of the time but yeah the bass is very less.if you like bass imo you should check something else.
if u really like bass then gor for EP 630…however my suggestion is MP21
hey where is mp 21 available for 700 ?
I guess was price around 900- 1000
and pl 30 would be better at that price than mp 21
no where on the net i could find mp21 at 700 :frowning:
MP-21 mic will not work with Nokia,SE and Samsung phones
I am also looking for a IEM …
i need some bass which is better?
PL21/MP21. Excellent bass.
The PL 30 is a better balanced IEM, it does not have bad bass response, it is just that it is more in line this can be remedied with the bass adjuster switches between Clear Bass and Heavy Bass as well they come with excellent foam tips :).
The PL 21 on the other-hand, the bass is overpowering in my views, used both off them, go for whichever you want. But personal like prefer the PL 30 as I listen to metal and alternative rock where I need a more balanced sound not overpowered bass and underpowered treble.
Link to order the SoundMagic PL 21 @700/- SoundMAGIC PL-21 In-Ear Earphones
hie… anyone knows where i can have SoundMagic PL30 in delhi…???
You can buy from Media Home right here..y buy from a shop when u get the warranty as well..aslso you can try primeabgb.com
i am planning to buy a PL30 for my nokia xpress music… does it really sound good with average mobiles.. or is worth buying only if i hv a good mp3 player?? btw, what does burning in mean…
I have been using PL-30 with my Nokia 5800 Xpressmusic for a really long time. It sounds excellent. But do bear in mind that the bass is a little less. It is said to be balanced. But it is definitely there. In certain songs you will hear the thumping bass.
Burning in: IEMs are mechanical device and improve with usage. With my PL-30 I did see an improvement in bass with burn-in. By that time I also got used to using an IEM for the first time.
^^ thanks baccilus.. for how much did u buy it? i am planning to buy along with a E3/E5 amp…
ebay is selling it for 2.5k which is too costly i hope… is there any other better deals?? any shops in chennai selling PL30??
You can buy them from here: http://www.techenclave.com/pristinenote/soundmagic-pl-11-and-pl-30-a-194543-3.html
I personally don’t feel that an amp will be helpful with PL-30 but I’m no expert on this.
I got it for 1K (including taxes) from Lynx around one and a half years ago. Another IEM you can look at is Brainwavz M1 from Pristine note for Rs1580/-.
You can get the newer Soundmagic E30, that would be even better. Be it pl30 or its newer version e30, they dont really need amping. And yes, they would sound good with a good music phone like the xpress music series.
looks like pristinenote doesnt hv PL30…
how abt this? looks a good deal…
Lynx-India - Online eStore Selling Soundmagic PL-30 Earphones In India
is lynx-india a reliable store?
Lynx is the authorized dealer for Soundmagic.
But his after sales service is not very good.
yes… i cud see lot of negative reviews for lynx-india… theitdepot has PL30B… wondering of both PL30 n PL30B r same…
— Updated Post - Automerged —
any positive takes on lynx-india?
