I have been thinking of buying S24 ultra as the price has reduced drastically and it was available for 80k on Amazon in the recent sale. I don’t wanna spend north of 80-85k on a smartphone. Only thing bothering me is the charging speed as I always used phones that come with charging support of atleast 65W and I am a guy who charges his phone at very last moment.
The other options I have in my mind is Vivo X200. I am currently using vivo itself and no problem with the funtouch OS but I can’t genuinely justify spending so much for a vivo phone.
The last option is to buy a budget flagship phone in the likes of vivo x200fe or OnePlus 13s and spend the money saved on other tech stuff waiting on my wishlist to buy😅
A little about my usage: I manhandle the phones I use. Like I use no cover or screen protector and drop phones quite a lot and end up spending more than the price of the phone just on screen replacements. But I think if I buy an expensive phone, I might take care of it for a while, atleast. I am kinda power user, have lot of stuff running on the background. I rarely game on my phone, and when I do, it’s usually those brain rotting ones you stumble upon through Insta ads😂.
I am also open for other smartphone options under my budget.
Just one thing, these phones have weak display protection, they get scratched very easily, even at level 4(if you know the terminology). They have cut corners.
Would suggest to get s24u from the corporate store, was roughly 72k, you get one year accidental damage for free, else s24u enterprise edition,which is same s24u, with 3 years warranty and same 1yr accidental damage for free, was approx 75k.
If you use the phone w/o a case & tempered glass, start doing that.
Maybe just buy a compact phone & use a case, the increase in bulkiness with case will still be less than bulk of S24U (size & weight).
If camera doesn’t matter much, OP 13s is good.
If you want better cameras than OP 13s & don’t mind about vivo’s UI & slightly lower performance (similar to 8 Gen 3), x200 FE is a great choice for you.
I’d rate UIs in the following order:
Samsung > Oppo/Oneplus > Vivo > Xiaomi
