hi friends…i have bought new i10 ,which has got sony’s sound system(sorry i dont know it’s model no.) installed with four 6inch speakers but i also wanted to add subwoofer to it…,so i wanted to know will it be possible and will it require amp. also to be added…?
A SUB Woofer cannot function without an amplifer. So you will have to buy an Amplifier for sure. On top of that you will also have to buy an enclosure for the SUB woofer and also a wiring kit.
Even if you buy all the basic stuff, it will cost you slightly more than 10k.
Sony 2-ch AMP~3.5k
Sony SUB-woofer~5k
Wiring~1.2k
Enclosure~800
Thanks manojbhagat for your reply..
Or you can go for specific subwoofers with built in amps..( jbs are decent entry subs)…better mating imo.
