Suggest a good air cooler for my Ryzen 5700x
My budget is within 3.5k rs!
In that budget, would look at deepcool ak400…I am using a hyper 212 with push pull for my 5600 and it works fine as well. Dont know if it will handle a 5700x
https://mdcomputers.in/product/arctic-freezer-36-cpu-air-cooler-acfre00123a?gad_source=1&gad_campaignid=22231680385&gbraid=0AAAAADRvfA7grBDubxWvYnVO6z6v8-oLX&gclid=CjwKCAjwq9rFBhAIEiwAGVAZP1rGvd4mt0XcCQaS__qye4bohCCzVeufxx0hXSqwt__Mdt0mqGi3ERoChNEQAvD_BwE
Arctic freezer 36. I have this and keeps my 14600k cool (although I undervolted it)
Choose from the following.
Link: https://sclgaming.in/shop/?yith_wcan=1&s=arctic+freezer+36&post_type=product&dgwt_wcas=1&filter_cooler-type=air-cooler&filter_cooler-socket=amd-am4
Thanks. Is this website trusted? Can I purchase from here?
Read this once: Have anybody bought PC parts from SCLGaming? Is it reliable and trustworthy?
With that budget I would get the AG620, used it on my 5800X and it worked far better than expected.
Should outperform most single tower coolers too in that price range since its a dual tower cooler.
https://pcpricetracker.in/gen/products/75c8e992e14174d31253fef02639d7ea
Arctic Freezer 36 is 6 years warranty Vs Deepcool AG620 ARGB is 1 year warranty.
it an air cooler when last you claimed warranty on an air cooler. :laughing:
6 year warranty is more a gimmick in this case. unless they going to replace your fans for free.
Note the AK620 and AG620 are basically the same when it comes too cooling performance.
Thanks for linking that thread!
+1 AG620 over Arctic at similar price. Or cheaper single tower
Warranty on coolers seems unlikely to be used and price seems to be too close for a single tower vs dual. AG620 should have similar perf as AK620
Your choice is between the dual tower ag620 and single tower freezer 36. Both have their pros and cons and perform close to each other when noise is taken into account. The deepcool would cool slightly better but the arctic one gives more space and has higher warranty.
Btw you can also increase your budget to 4.5k and go for the peerless assassin on fk linked in this thread
I have a corsair carbide 100R case and it’s a mid-size tower. So I’m not really sure if something as big the peerless assassin would fit in with 2 sticks of RAM too.
Good thinking that you’re keeping your case in mind.. many of us forget that.. in space constraints.. freezer 36 is a brilliant choice imo
I am using lian li 206, so I should be able to fit in peerless assassin without any issue. Hopefully :sweat_smile:
Check here for Thermaltake CPU coolers prices and compare them with flopkart once: https://sclgaming.in/product-category/cpu-cooler/air-cooler/?yith_wcan=1&product_cat=air-cooler+thermalright
https://www.flipkart.com/thermalright-peerless-assassin-120-digital-screen-double-towers-fan-heat-sinks-pipes-all-one-cooler/p/itm282e2d92c8abc
4k
you meant thermalright right?
I have the AK400 paired with my 5700x and it’s more than enough for the CPU.
