Suggest a good air cooler under Rs.15k
Looking for an air cooler, for a room of approx. 180 sq feet.
Initially thought of buying AC, but we are planning to move out after couple of months, so not a good decision to buy AC now.
Regarding features:
  • Need something that can last for a while and not rust quickly.
  • We should be able to remove the pads and clean the inside and dry it when necessary (we get hardwater in taps and they cause lot of scales on plastic)
  • Remote is not necessary, but good to have.
  • Size: not sure how much is sufficient for 1 night continuous water pumping, I don’t have any prob replacing water every day.
  • Good to have features: Mosquito mesh, close-able flaps at the front.
Had Kenstar air cooler in the past and the service was terrible, so not buying anything from this brand.
Buy any water cooler (don’t buy Chinese maker ones though). When going for a cooler, it’s not which cooler you buy, but rather where and how you place that cooler at home.
You need to let air come in the room from the cooler and you need another opening to let air go out. I keep cooler in the balcony, face it inside the room, and keep the windows open in all the rooms.
If you don’t let the air flow out, it will get humid and you’ll die of sweat. If there’s a proper ventilation, you will have the temperature drop in your room better than an AC.
Air coolers just aren’t good enough at cooling to justify spending 1/2 the cost of an AC on them imo. I mean, what does a 15k air cooler do that a 6k one wouldn’t do almost as well? It’s just a fan and water being pumped over a mesh.
A portable air conditioner, although pretty inefficient compared to a split ac, would work for your situation but I’ve yet to see any great options in the Indian market. At 180 sq ft, this one is probably way too underpowered for you.
https://www.amazon.in/Blue-Star-Portable-Copper-PC12DB/dp/B07W6NX7BJ
Have symphony jumbo 70 in my farm house from 2017, no issue till now. Avoided ac bcoz of frequent power fluctuation (no separate line for agriculture and residence in that area).
Also portable ac creates lot of mess (drain water, exhaust pipe). Used for few days in shop, later replaced with split ac.
No need to spend too much, all air coolers perform similar.
As I mentioned in the first post, it isn’t feasible for me to buy ac right now and pay for multiple installations.
The airthrow, sound/performance of motor, the pads, efficiency, mosquito mesh, longevity etc. There are many things that differentiate the cost. Mostly in under 6k range, only personal coolers would be available which are not suitable for larger rooms. Moreover a good ac costs 45k+ nowadays.
Besides having an air cooler is an advantage as well, can be moved to different places without requirement of installation and can be useful when guests arrive and no ac in their room, or in places where there is no 16A or 20A sockets.
Portable ACs available in our country right now aren’t any good.
Heard symphony coolers are good, saw some reviews of symphony sumo and reviews are good enough. But they say it’s fan is made of plastic and not metal, is it same in ur case?
Yes the fan is of plastic but that’s the reason of its quite operation. Also strong enough to survive until any notorious kid put something while running.
@Ssreek you can consider this this:
https://www.flipkart.com/maharaja-whiteline-65-l-desert-air-cooler/p/itm06ceaf95fbc14?pid=AICERHNDQ5TZJEBN&lid=LSTAICERHNDQ5TZJEBNDJFAQB&marketplace=FLIPKART&cmpid=content_air-cooler_8965229628_gmc
Thanks for link, I’ll check this.
Hi, I own the [Crompton Optimus Desert Air cooler 100L](’
Amazon.in
) (it is 14k now, i’ve got it for 10k) and its been nearly 1 year since I’ve owned it. Its good given you have the good ventilation provided, cools the surroundings really good.
The air delivery is okay, not great. The only issue is with cleaning it.
[YT video](’
https://youtu.be/-vbynp0bRp8?si=HG692WrVBDrBwEik
I referred to similar video of last year, that video is private now. This is the latest 2024 suggestions.
I heard a ton of good things about Symphony and bought this last week:
https://www.amazon.in/gp/product/B09QG84WRN
It has been a huge relief in this heat. Way under your budget though so you could maybe look into their line of BLDC coolers. Symphony is highly recommended.
Hi all, after checking out few coolers in stores, finally bought a Symphony cooler. Thanks all for your inputs.
Update 2: If anyone is looking for a cheaper cooler (below 10k), the livpure koolbliss cooler is fantastic. Bought 2 of them for my relatives and they are quite happy. Got them for 7.2k each.
Hey man how is the air cooler working and would you still recommend it? Looking for an air cooler under 10k and keeping this in consideration; however many Amazon reviews (at least when sorted by recent) point to pump failure within/around 1month and poor build quality. How has your experience been with it? Thank you.
Hey all would really appreciate any inputs on good air coolers around the 10k mark. Plead also share your experiences with the brand and model you are using. Thank you.
Also, all prior links on this thread except the Maharaja are no longer available to purchase :frowning:
Hey how has this cooler been holding up for you? Would you still recommend it? Thanks.
Hi, sry I missed to see this somehow.
I’ve enquired about the coolers and my relatives are quite happy with the performance and both the coolers are still working fine.
One of the coolers needed a service and the service experience was great too it seems. Even I had good experience till now with service of other livpure products.
Regarding build quality, I felt it’s fine for the price. Doesn’t look cheap or feel flimsy. It’s good enough.
Thanks so much for replying! However, I am unable to find the Livpure coolers to purchase online anymore :confused:
Do you (or anyone else) have any experience with the below cooler (or the brands)?
https://www.flipkart.com/rr-90-l-desert-air-cooler/p/itmed0cf88a4e5a2
The livpure one frequently comes in stock and then goes out of stock for few days and then does same thing again. Just keep checking everyday if you are fixed on that model. We bought both of them from amazon.
Got it, thanks. Could you confirm whether this is the correct model?
https://www.amazon.in/Livpure-Koolbliss-Delivery-Honeycomb-Compatibility/dp/B0CSNB2CS8
If not, could you kindly share URL for the one you have had positive experiences with? Thank you.
Yes that is the model. It was in stock last week or so.
IMHO don’t go for symphony. They break easily and are not easy to service. Plus they make a lot of noise
I went for crompton Optimus 65. It does not have a remote, but boy does it cool. It has mesh on 3 sides, plus the water comes to top chamber like old desert coolers.
Basically for air coolers, the bigger the mesh, more cooling. The Optimus also has auto filling and draining valves. Being a fan based cooler ( not blower) it’s quite also. Please don’t go for personal coolers, they don’t cool anything
