Hi all,
I’ll be getting a camera from US. Can you suggest me some good ones( I have no idea where to look for). The requirements are,
- Compact
- Usable by novice.
- Decent clarity and zoom.
Plz help. TIA.
Hi all,
Plz help. TIA.
u seem to have the same requirement i had when i got mine abt 2 months back…so i will suggest the same thing i got for me , i.e the CANON IXUS 70…very compact , exxxcellent photo quality / well yes its a CANON \ …compact , the shirt pocket is actually big for it …easy to handle , nice screen , face recognition , decent macro and manual controls too…i got it from abroad , however it easily fits under 12k here in india now , jus checked jjmehta they selling it for 12k with a 1gb card…+ pouch + 2 yrs of indian warranty , excellent go in for it…eyes shut…
Newegg.com - Canon PowerShot SD870 IS Silver 8.0 MP Wide Angle Digital Camera
Newegg.com - Canon PowerShot SX100 IS Black 8.0 MP Digital Camera
Newegg.com - Canon SD850 IS Silver 8.0 MP Digital Camera
Newegg.com - Canon PowerShot A720 IS Silver 8.0 MP Digital Camera
Thanks hanzy, Udit for superfast replies ![]()
I have decided for Canon IXUS70, mainly because to compactness and point-and-shoot operation. and they are giving away 2 gb card free
Only thing it lacks is image stabilization.
buy Canon PowerShot SD850 IS (Digital IXUS 950 IS) as it is the same size with image stabilization ![]()
But it is for 80$ more! That’s quite lot. Anyways, I was quit bent on sx100 as well, I’ll get that if I plan to spend that much. 10x zoom looks enticing ![]()
I think sony is best for shaky hands.
Thanks for that generally generalized statement. ![]()
@Deus Ex: Lemme give you some recommendations
Always opt for models with Image Stabilization. Trust me, this matters. You don’t want all your non-flash night-snaps to come out blurry and then blame your camera for it. You can add memory later but not image stabilization.
Go for features and a 1GB card right now. Add in another huge card later, even with all the photography I do I have never run out of space on a 1GB. ![]()
What features? IS, wide-angle lens (<35mm), a big LCD, build quality and Li-ion are top on my priority for a compact.
Brands/Models?
Sony W80/W100/W200 - IS, excellent build quality. BUT no 28mm wide-angle, only 3x zoom
Canon IXUS series with IS - look for 28mm models. Excellent build again but limited zoom range mostly.
Panasonic TZ3 models - 28mm, 10x zoom, and IS. And compact.
Fuji F50fd - IS, excellent low-light shots, very good build. No wide-angle.
That’s my choices. You know what to get, shop right and do post if you have narrowed down your choices.
Payne
PS: Please don’t buy stuff for “offers”. My friend bought a Kodak $&*@ cuz it got a 2GB free.
Please.
Those are my pick. Look for the ones which
@Payne
Had I been buying this for myself, beleive me I would have considered. But this is a case of a female friend(that makes it harder to explain
) gifting this cam to her parents. So my prime criteria were compactness and point-and-shoot interface.
Anyways, I know how important IS is. So I have settled for SX100. I’m a big fan of Canon so don’t really feel like going into Sony’s territory
Rest of the brands she might not have heard about and hence skeptic about.
The 2 GB card is NOT a criterion but I would prefer getting it free ![]()
Double post! X-(
Fair 'nuff.
If you’re looking at the Canon SX100, you can also look at the Sony DSC-H3. I was a fan of Canon till I ended up with a Sony H2. Faster focus, great navigation system (jogwheel system) and better control. Of course, the Canon alternative had a better screen.
Digital Cameras Side-by-Side, 2 cameras: Digital Photography Review
That’s for your help. The biggest difference is that the Sony is lighter/smaller and has a MUCH stronger flash + battery system which helps a lot in social parties/normal snaps. The Canon has more manual control and so is better suited to the enthusiast.
Take your pic. (no pun!) ![]()
Payne
PS: Btw, I still feel you’re better off with a Canon Ixus or Sony W-series or the Panasonic!
Enjoying with my Sony DSC-W70 from long!
If you travel around and take your camera around, clicking unnecessarily, get extra battery and a larger card.
Video recording is awesome as well at full quality! That’s how my 1GB card fills up easily
Usually at stage shows and parties..
