I am planning to buy an 1 KVA UPS for my LED TV. I would like to have around 30mins to 60 mins backup. While on battery the UPS should not keep beeping.
I have an APC UPS for my PC - it is good but keep beeping every 30 seconds - so it is not usable for watching the last bit of the movie when the power has gone.
yup he is right, you can turn off the beeping, I had a couple 650VA UPSs and now bought a 1KVA from APC, it doesnt keep beeping, unless there is an issue.
AFAIK this feature is only available in “smart” series or whichever UPSs come with USB connectivity. I also have Back-UPS 600, but no such feature of switching the sound off. The feature is activated through software, UPS being connected to PC via USB cable.
^ you’re right. I think the TS has apc smart ups with usb connectivity.
#bikeadvice, If using the smart ups with tv, you can connect the ups to comp via usb cable first time. install the software, disable the beeps forever in settings and then use it with tv without the usb cable. The ups wont beep when it goes on battery or any other time, only when you switch it on/off.
Smart UPS from APC should have the option to turn the beeping off, if you have a powerchute business edition then the option comes under configuration just put the option 'Audible Alarm ’ to ‘Never’ and click apply.
