Suggestion for 32 Inch Monitor
Hi… I am looking to buy a 32 Inch Monitor for Gaming & 3D Drawing related purposes..2k Mainly , 4k if affordable in my budget…No Curved Display
Kindly suggest me some Monitors for Budget 30k-35k…
LG Ultragear QHD (32 inch / 80 cm) 165 Hz 1ms, Nvidia G-Sync Compatible, FreeSync Premium, HDR 10, HDMI, Tilt, Height, Pivot Stand, VA Panel Gaming Monitor (32GN650) Amazon.in
While mine is the below one
LG Ultragear 80 cm (32 inches) QHD (2K) Gaming Monitor with 144Hz,1ms, Radeon Freesync, Display Port, HDMI x 2-32GK650 Amazon.in
Both are VA panels but I am not able to understand my monitor is costly than the one I suggested because it’s having HDR 10 which my monitor does not have.
So decide for yourself which is best. Okay.
Difference is in the seller. The 32GK650 sold for 20-21k last year. HDR10 is pointless in cheap monitors because the peak brightness is too less and it results in a worse experience with HDR switched on. Also, the GN650 is 95% sRGB compared to 99% sRGB for GK650.
How is the reviews of 32GN650? any other similar alternatives? is ips better to va models?
Which GPU do you have? Do you need a high refresh rate display or you’re satisfied with 60 FPS?
If you don’t need high refresh rate, I’d recommend going for 4k instead of qHD, it will give much sharper image for your drawing needs.
If you do want high refresh rate, make sure your GPU has enough power to drive qHD at 100+ FPS.
I have a 6800xt gaming z trio .. i want mainly for drawing needs .. so higher refresh rate is not must .. i want something balanced
no need to buy gaming monitors.
get a 2k with 75hz refresh for art, its better.
I purchased a lenovo last year 31.5, but OOS now
there are good monitors with 2k, 31/32 inches and 75hz.
Get a 4K60 IPS monitor instead as you will appreciate the larger real estate at higher resolutions when working between applications or even on a larger canvas.
I’d seriously recommend 4k for 32". The difference is sharpness is very much evident.
How is this monitor? Any other better 4k 32inch 60hz monitor available?
Or these 2 models?
Link - Amazon.in
Link - Amazon.in
I generally refer to Rtings for monitor/tv reviews. I did similar research last year and found BenQ EW3270U quite good barring HDR and brightness for this price point.
Also stay away from ones with BGR subpixels for productivity use.
