Suggestions for a 22" Monitor
My friend is looking for a 22" monitor for his office work, he does mostly CAD and Solid Works stuff.. Any monitors you guys recommend? I went through Amazon, there are lot of mixed reviews, couldn’t finalize on anything.
p.s: HDMI connectivity and 1080P is a must, cost preferably under 10k
If the PC is rocking an AMD GPU, then I’ll suggest going for Freesync Compatible Monitor as it will be really fluid for CAD and Solid Works.
I have this one as a dual monitor set-up and it’s amazing.
LG 24 inch Gaming Monitor
If not then these:
LG 22 inch (55cm) LCD Monitor
Lenovo L-Series LI2264d
HP 21.5 inch (54.6 cm) Edge to Edge LED Monitor
He has an 4th gen i7 currently, thanks for the suggestion. I was leaning towards the lg 22 inch. but there were quite a few negative reviews hence this post..
Well, there will always be a few negative posts for any product out there.
Anyway, go for the LG monitor! It’ll be good.
LG one also supports AMD freesync so theoritically if your friend has AMD or now pascal or turing GTX cards, it can support Gsync
Ok, will ask him to get either the 24 or 22" LG. thanks for all your suggestions people..
LG 22mp68-vq, if you want within 8-9k.
