Suggestions for a good quality 1200W PSU? Preferably white
Title says it all. Don’t mind spending a bit more but want a good quality PSU. Suggestions?
So many options, Thermaltake also comes with RGB, Corsair and ASUS ROG are there too.
I think this is a A+?
Buy NZXT C1200 Gold ATX 3.1 Fully Modular Low-Noise PC Gaming Power Supply (Black) - Computech Store
You can get super flower super-flower-leadex-vii-platinum-pro-1200w-atx-3-1-white platinum-rated
My Current default recommendations are either NZXT C1200 ATX 3.1 or RM1200x Shift ATX 3.1 or Super flower leadex vii PP 1200W ATX 3.1
All 3 solid A+ grade psus. All 3 are relatively silent even under moderate load. If buying Corsair RMX, just go to their website and make sure your case is in compatible list. The button to search that is right on the product page in yellow colour.
Another thing to keep in mind about NZXT C1200. ITs cables are all super high quality thick, and all are covered in a nylon sleeve. So they are high quality but stiff. If you are working on a small case, those will create issues. ITs still possible to route em properly without damaging but it takes that much extra time and patience, and force, which might feel uncomfortable at first.
